2020 1000RR-R Rear sprocket upgrade
Discussion in 'Mods, Upgrades, Accessories and Products' started by Jay Floyd, Apr 14, 2022.
  1. Jay Floyd
    Jay Floyd Active Member
    Hi all, well I ordered a 43T rear sprocket from RRRPS for my 2020 blade. the standard gearing is 16T/40T as it’s well known that the 2020/2021 model lacked bottom end grunt, and had to be ridden like a 600, which I found out to be slightly annoying.
    so I’ve fitted the 43T rear sprocket, so now my gearing is the same as the 2022 model! Holy crap…. What a difference!! The bottom end grunt is just amazing… no errors on the dash either!
    all I can say …. It’s a mod that needs to be done. Also the speedo. Is correct too, as I checked it with a GPS app. So happy days!!
    • Like Like x 10
  2. Flumpster
    Flumpster New Member
    HI have you had any issues with the quickshifter ? Ive a 2021 blade and would like to change the sprocket but was told I needed an HRC loom because the traction control and quick shifter wound not work correctly
  3. Jay Floyd
    No, I have had no issues with QS or TC and i use my bike on track and road :) Awesome upgrade, just make sure you turn up the anti wheelie :)
