A reminder for everyone to check their oil every ride!
Discussion in 'Maintenance' started by martinowen, Mar 3, 2013.
  1. navvy10
    navvy10 Well-Known Member
    Yeah I think it's around 300ml by my last top up. but then I'm not the most accurate of measurers....
  2. Sossige
    Sossige Active Member
    Ta chaps.
  3. steveh
    steveh New Member
    Sossige..... Are you screwing / unscrewing dip stick..?? If so could make it look like overfilled. You've got to dip without screwing in, if that makes sense...
  4. navvy10
    The garage told me you have to screw it in as I specifically asked as that makes at least 10-12mm difference. I found you have to screw gently so the oil doesn't splash up all over the dipstick. And this has nothing to do with sex :D
  5. navvy10
    Just checked the manual to be sure and you're right it says dont screw it in. Mechanics aren't as knowledgeable as they think....
  6. Sossige
    Hi, no, not screwing the dipstick in - as per manual and label on the dipstick.
    Cheers,
    S
  7. Guymx
    Guymx New Member
    Checked mine after reading this and it needed a 1.5L top up! Phew!
  8. navvy10
    I put another 300ml in!!
  9. Garyb
    Garyb Moderator.
    Kinell, did you change the filter while you was at it?
  10. martinowen
    Bump again, I know mine was never oil level in the end but it has made a few people realise get were getting very low!
    Check it people
  11. Frost1
    Frost1 Active Member
    Just read the whole thread, some lessons learned there. Glad it all went well, Atrhur is indeed a top bloke for all he did :)
  12. madmac
    madmac Well-Known Member
    Yup. I think we all need an Arthur near us. Bike ownership would be a lot easier... :)
  13. lambchops
    lambchops Elite Member
    saw this thread and was like no way sorry to hear this Martin!! then saw the date a did a sigh of relief!! What was the issue in the end couldn't read it all?
  14. martinowen
    My gearbox, 2 teeth broke off of 4th gear!
  15. lambchops
    Ah I see, lucky escape then! Amazing they broke apart like that... No more clutchless down shifting for you then :)
  16. ExDaytona675
    ExDaytona675 Active Member
    I just read this entire thread and it is really good to see how many top blokes there are on here. I also own a BMW (in addition to my 08 Fireblade) and use their forum a bit and to be honest there are a lot of tossers (hence their nickname) on there. There is no way you could have gone through a 44 page thread witout some smartarse jumping in without a derogatory comment or criticism of spelling. There is however a lot of abuse about sportsbike riders in general and a rather holier than thou attitude towards other bikers. I think I'll stick on here in future!
  17. benp1
    benp1 Active Member
    Quick oil question - what brand/type are people using?
  18. travellingkiwi
    travellingkiwi Active Member
    Amazingly enough... I've never put any in mine... It hasn't used a drop in 8070miles... And the dealer does the servicing so far...
    H
  19. lambchops
    Random place to post about oil... But I use castrol racing, did use the fully syth but have the semi in now.
