ABS Plastic Repair.
Discussion in 'Maintenance' started by nigelrb, Sep 23, 2018.
  1. nigelrb
    Hi. Can anyone help with recommendations for plastic repair?
    Have a couple of 'vibration' cracks on my VTR fairing and hugger, both plastic. The hugger has to be repaired around the bolt hole areas which I acknowledge as being a permanent risk.
    I had considered fibreglassing, but does anyone have experience with the variety of plastic epoxys such as this:
    https://www.powermaxed.com/epoxy-adhesives/power-maxed-plastic-bond-syringe
    Cheers:).
  2. Boothman
    Boothman Elite Member
    #2 Boothman, Sep 23, 2018
  3. 1000rr73
    1000rr73 Active Member
    Sounds like a great way to fix. I’ll use that method if I ever have the need. Cheers
  4. nigelrb
    Thanks for that @Repsol Ron . Will make an excellent repair and prevention of further probs. I've known of the 'backing sheet' method from a previous life, but did not even consider it for this 'minor' repair. The 6mm holes in the backer though, are the pièce de résistance.
  5. Cream_Revenge
    Cream_Revenge Active Member
    Q-bond. Needs rubbing back and filling to make it look nice.
    Check out You Tube.
  6. Boothman
    #6 Boothman, Sep 23, 2018
