I am selling all my Accessories which were installed on my 2011 ABS Repsol Blade. 16. Accossato teflon quick action throttle CNC red with cables #4 http://1000rr.co.uk/mods-upgrades-accessories-products/13260.htm NEW Accossato teflon quick action throttle Universal, Eiweiss-Raceparts The gas control in Ergal 7075 ACCOSSATO is the result of a study carried out directly on the race of sports trophies and World Superbike. The product is made of aluminum alloy produced entirely CNC. The kit consist of 2 outer shells, three wheels of different diameter. The possibility of having three different wheels from the possibility of adapting any kind of guide to every type of motorcycle. - quick action throttle kit with cables - the outer shell comes in red ! - the Diameter from the different ratio wheels is 37 / 40 / 43 mm. The Teflon coating of the slide tube allows precise dosing at the lowest possible friction - even the tiniest throttle movements are implemented. The smooth throttle cables can be combined to achieve the desired ratio with an included three eccentric. Complete kit with all mounting parts for use in place of the series gas handle. The ACCOSSATO gas control are one of the most popular products, at an international level, because they are used by the most important Superbike, Moto 2 and Moto 3 teams. GBP 85 Delivered SOLD
Accossato teflon quick action throttle CNC red with cables The stock throttle is a 1/4th turn which is 90 degrees of rotation from full close to full open. The HRC 1/6th kit is 60 degrees of rotation. The Accossato Diameters are 37 / 40 / 43 mm etc. different ratio wheels. Standard is between 35 and 37mm, depends on the bike. For example ( here with SCM Quick Action Throttle ): Cam Designation/// Reel diameter (mm)/// Full throttle angle (degrees)/// Cable draw (mm)/// increase in throttle response vs OEM OEM/// 35/// 69/// 21.07/// 0% 57/45/// 39/// 62/// 21.07/// 11% 57/49/// 43/// 56/// 21.07/// 23% 57/53/// 47/// 51/// 21.07/// 34% 57/55/// 49/// 49/// 21.07/// 40% Also, you can not compare the HRC with the Accossato. The Accossato build quality and the flexibility ( Reel diameter etc. ) are much better than the plastic HRC. product.
