Aldli Torque wrench
Discussion in 'General 1000RR Discussion' started by Mad Matt, Oct 12, 2014.
  1. megawatt
    megawatt Well-Known Member
    Scooby, you guys will love this, I only use a torque wrench to torque cylinder heads down, in stages. I don't generally use one as I have learnt over the years and stripped a few threads with torque wrenches, that I can tighten a bolt into an aluminium crankcase without stripping the thread or the bolt coming loose. I bought the Lidl one for people to use when I am showing them how to work on their bikes.
    Fair point Matt. The Teng ones are good quality, but not sure if they are any more accurate or repeatable than Aldi.
    I would be interested in how people prepare bolts and bolt holes ready for torquing up. A lot of mistakes made in just this part. As for torquing up a wheel spindle nut, just tighten it until you FART !
    #21 megawatt, Oct 14, 2014
  2. scooby
    scooby Elite Member
    thats actually a good point regarding how clean threads are,bolt holes etc.thread lock on bolts or copper slip on caliper bolts will effect the torque values due to too the lubrication of said fluid,so in theory you will be over torquing your bolts.
  3. coupe312
    coupe312 Active Member
    torque till you fart.... love it .... if i did that everything would go ping... i used to snap wheel bolts on a car all the time... too heavy handed to do that.... im not skilled enough to know that enough i need a number to say stop
  4. megawatt
    Just the rear wheel spindle nut mind. Torque wrenches are good, but not the be all and end all.
  5. ozzer76
    ozzer76 Member
    I have no mechanical skill whatsoever but what I would say is, I bought the Aldi wrench and I've used the Aldi TW to take off the wheels from my bikes and they work just great. When I bought it from Aldi I was shopping for snacks and spent less than £28 and come away with a TW and tons of food and drinks too!
    It's a fair old size too. If they brought out a smaller version I'd have no probs buying another.
  6. Dave
    Dave Member
    Have to agree with Scooby, torque values change with condition of bolts/nuts being torqued by that i mean lubed or dry and also tensile strength of said bolt. A good torque guide will give the correct values for the condition/type of fastener.
  7. Repsol Rob
    Repsol Rob Elite Member
    listen I ll tell you all what its like when I get mine.......tom ! ;) ................along with my cheap food substitute's !!!!!!!
  8. Repsol Rob
    if it clicks and feels tight it will do me Al....... good help if it comes loose in Almeria !! lol
  9. Stevie_d
    Stevie_d Senior Member
    Let us all know what these are like Rob if your still off to Aldi
  10. Alblade
    Alblade God Like
    Loving the Aldi clones!
    Titans are my favourite, plus seal bars (Mars and Penguin )
  11. Hudson
    Hudson Active Member
    I have already got this one..... use it every now and again (when i have too cos i am scared !) I would have liked a digital one where you just put in the number of torques (sp) you want and away you go.... but i understand they cost a fortune and for what i do with it that seems a waste.
  12. Jonnymac
    Jonnymac Active Member
    Halfords professional. Never had a problem with them for the money. Lifetime guarantee too
  13. rtasker
    rtasker Active Member
    I like the sound of that. To use one of my torque wrenches it's necessary to convert the required torque (usually quoted in Nm) onto a kg_m scale of 10 units per 1.4kg_m. What a pain!
    #33 rtasker, Oct 16, 2014
  14. el-nicko
    el-nicko Well-Known Member
    So will someone who already has one of these put the rest of us out of our misery by posting it's range and drive size?
  15. kpone
    • Like Like x 6
  16. Repsol Rob
    Well I got it............
    Will try it out at weekend when I fit the serviced 2012 forks and re valved (all by Ktech) 2012 rear shock !! but hey that's a different story !! ;)
    Compared it to a good mate who's got the draper and it's very similar
    3yr warranty too can't be bad
    Now munching my malt flakes !!
    #36 Repsol Rob, Oct 16, 2014
  17. Repsol Rob
    Oops the frosted flakes took effect !!
  18. sinewave
  19. Repsol Rob
    cant access page........ only for privileged ones and stirrers no doubt !! :D
  20. Muffking
    lol, I read that when it was posted and thought it was his car, a Vauxhall Signum, then I realised he wrote Sigma clutch :D
