another chain lube video!
Discussion in 'Maintenance' started by bonjo, Jun 1, 2019.
  1. bonjo
    bonjo Active Member
    would you change your trusted poison?
    • Like Like x 7
  2. Sp0oner
    Sp0oner Active Member
    Thanks for posting. I’ve yet to find a trusted chain lube in 25 years. I currently use muc-off and it cakes my rear wheel and didn’t stop the chain on my previous bike from rusting during Winter.
  3. Jez
    Jez Senior Member
    Always used wurth dri lube as it does not mess up the rear wheel. good vid
    • Agree Agree x 4
  4. bonjo
    bonjo Active Member
    I also use wurth. You will get next to no flinging.
    The coating is very light and would not provide rust protection in the wet. You can make it better by applying few layers over each other (I use the bike in between)
    But I don't think there is an answer to winter riding on salted roads othe that cleaning after each ride and putting some xcp lube on
  5. Jez
    Jez Senior Member
    Only had 2 rides as wont use in the wet :( But hoping for Yorkshire TT tomorrow :)
  6. BlackDevil
    BlackDevil God Like
    https://www.amazon.co.uk/HKS-Czech-Dubbin-Extrem-grease/dp/B01E3VS670
    Product description
    HKS extremely the Juwel under the lubricants for extremely high-pressure necklaces with long term effect HKS extremely is a dünnflüssiges lubricant that when applying, the integrated capillary effect to the smallest Hohlräume reach, so always a string of optimum lubrication even in the interior, the hochbelasteten chain bolt, installation time. After 3 - 5 minutes Abdunst - Ungszeit builds up a greasy film similar to the form of a plastic coating with long term effect. The Greasy Film is 3-5 times thicker than ordinary lubricating films, so makes it Ruckdämpfend and chain sequence noise are extremely are reduced. HKS extremely produces a durable, thick fully waterproof a greasy film similar to the form of a plastic coating HKS extremely has an extreme suction and reaches up to the hochbelasteten friction spots against HKS extremely Sealed against dirt and water HKS extremely will not Abgeschleudert HKS extremely lowers necklace nachstellung much HKS Super ensures a smooth running, without loss of performance HKS extremely acts very quiet and Ruckdämpfend HKS extremely no chain cleaning for to smudge HKS extremely completely o/x/W Ring compatible with 2500 km chain lubrication intervals 6 attributes that only HKS offers. 1 Sealing effect: prevents dirt and water from entering 2 Langze Itsch Mier Movie: 5X longer lubrication Erinte Rvalle than conventional chain lube oil 3rd for quickly ready for use: After applying the cream in 3-5 minutes ready for use, will not Abgeschleudert 4th 5 x thicker a greasy film layer thickness: Noise Of Ruckdämpfend and Verschleißmindernd 5th the smallest dose: allows economical and targeted consumption No environment pollution 6 optimal care of the chain Innenlebens: securely attaches to the hochbelasteten chain bolt package size: 300 ml spray can
    #6 BlackDevil, Jun 23, 2019
  7. bazzashadow
    bazzashadow Elite Member
    I can’t read that :eek:
    I have enough reading english;)
  8. Jez
    Jez Senior Member
    Next Vid will probably say the earth is not flat, I will stick with my trusty wurth snake oil and feel contented my chain is happy:)
  9. BlackDevil
    BlackDevil God Like
    Try again...
  10. bazzashadow
    Wish I was quicker at reading its sold out now;)
    #10 bazzashadow, Jun 23, 2019
