anyboday taken the plung for lithium batterry?
Discussion in 'Mods, Upgrades, Accessories and Products' started by bonjo, Aug 24, 2017.
  1. bonjo
    bonjo Active Member
    I am considering one of these when I next change mine (probable next winter after 2.5 years)
    Has anybody done so on their road bike (not racing only) all year use including winter?
    what is their performance like during the cold weather?
    How does the bike charging handle it?
    In the Honda RR8 service manual, the charging system test states charging voltage of below 15.5v @ 5000rpm.. Now all lithium battery manufacturers state a maximum voltage of high 14v. So I am a little puzzled taken 15.5v of Honda at face value, the battery would fry!
    Yet manufacturers list batteries for this bike
  2. Nene
    Nene New Member
    Hi Bonjo,
    Although I can't answer your question today I've got a Lithium battery ready to be fitted either this afternoon or tomorrow....Watch this space :)
  3. bonjo
    bonjo Active Member
    great :) while you are at it, would you mind measuring the volts at the bat terminal with the engine running @ 5000rpm (if you decide to test run the engine):)
  4. Nene
    Nene New Member
    I'll see what I can do. Just off to fit it now.
  5. sps170373
    Got a lithium battery ( shorai) in mine and runs fine! Don't see more than 14v when charging (hm dash battery function) and yes I do use mine on the road
  6. Nene
    Nene New Member
    Well as sps170373 said there's 14.18 volts across the terminals at 5k rpm. Time for a test ride.
  7. Dave dunlop
    Dave dunlop Elite Member
    SPS on mine now, 3rd season and still going strong with no issues, I do remove it from the bike over winter months :D
  8. si1000repsol
    Switched to Lithium as I was finding the batttery was flat every time I came to the use the bike.
  9. TheMickster
    TheMickster Active Member
    I had one on the trackbike, but i've switched back to a normal one for the road just because I didn't want to buy a specific Lithium charger and i've already got an normal Optimate. I discharged it too much sorting the wiring and testing lights and idicators etc without the bike running.
    If you remove them from the bike over winter etc they last for ever (It came with the bike when I bought it and I never had to charge it. Really light weight too.
    I'm not sure if the one I had was up to the job, was really small, about a 1/3 the size of standard one, I did have a few probs with HM Dash not powering up every time (never got to the bottom of it, not sure if it was a dash problem or related to the battery)
    Don't know what they are like with alarms etc and leaving them on trickle charge.
    Are the Blade specific ones the same dimensions as the standard battery?
  10. Nene
    Nene New Member
    Everything seems to be working fine after a quick 50 mile trip. Put the bike onto the Optimate charger and it gave a brief charge followed by the green retention test light which is good.
    I also weighed the original Yuasa battery which came in at 3kg!!! The Aliant YLP10 that replaced it is only 754g, so that's nice :)
  11. sps170373
    Don't forget you can't use a normal optimate as the desulphate mode will knacker the lithium battery!
  12. Nene
    Nene New Member
    It's ok I bought a new Optimate designed for Lithium batteries....go me
  13. Jez
    Jez Senior Member
    I have lithium battery on mine, I only use on sunny days, I have put a solar charger with a 13.3v cut off on it works well, these battery's like to be stored at a lower voltage to extend life, also has an alarm fitted
  14. gixxerjim
    gixxerjim Active Member
    i need a new battery, considering this.
    if you get the correct optimate charger, do you plug it in all the time as a normal battery reading Jez comment above about them preferring to be stored at a lower voltage?
    and how do you know what to get?
    looking on ebay they fit a blade, but have diiferent capacities so what is the recomended?
    http://www.ebay.co.uk/itm/LITHIUM-B...05-/282085941583?_trksid=p2349526.m2548.l4275
    http://www.ebay.co.uk/itm/LITHIUM-B...407307&hash=item3f65ecf734:g:o8cAAOSwhOVXdlLW
    cheers jim
    #14 gixxerjim, Aug 28, 2017
  15. Jez
    Jez Senior Member
    I would have thought if it has been designed to run lithium it will be ok to leave on all the time, leaving a lead acid charger on a lithium will over time cook it, When lead acids are fully charged they stop taking a charge, lithiums will still keep charging.
  16. bonjo
    bonjo Active Member
    I checked my charging voltage as per the service manual : meter at the bat terminals, engine running @ 5000rpm and I got 14.5v which is great. The manual says , 15.5v which would fry a Lion battery and simmer a led one!
    What are they like to use in cold weather like our cold English winter (not Scottish!) say on a 5 deg C day?
  17. bonjo
    bonjo Active Member
    they are for different bikes! Check this carefully as fitting will be an issue.
    given the choice and money, go for a bigger capacity one (which would still be much lower that your OEM battery).
    LION battery are a lot more demanding in terms of looking after. If you use a dedicated charger, then charging will stop once the battery is full but if you use a non sulphating Led battery charger, then you have to manually disconnect!
    I done some readings about the do's & don't's of how to deal with LION bats and what to be aware of when choosing one since my original posting. I may put together it in a condensed form as a post which you may find helpfull
  18. bonjo
    bonjo Active Member
    Just to catch up on your battery. How is it performing in the cold weather?
    I noticed The terminals are centered! Did it cause any complication with the stiff & short battery cables?
    Would apprciate your feedback
    PS what year is your bike and wothout ABS?:)thanks
  19. Nene
    Nene New Member
    Hi Bonjo,
    So far even in -6C the bike starts first time every time. I do keep the bike in my garage and always connected to a trickle charger (Yes lithium approved type ;) )
    And no problems connecting up extra wiring for things like the quickshifter and heated grips.
    Mine is the 2014 with ABS.
  20. TheRamJam
    TheRamJam Well-Known Member
    I went for a Skyrich battery. So for so good, starts on the button and was reasonably cheap at £78 delivered.
