Hi everyone I know Remal Dan have crc fairings . If anyone had not tested them yet I'd recommend putting 2 fixings in the rear of the tank/seat base fairing as when at mallory it rattled about so 2 little screen bolts she's solid ! My seat height has seemed to rise slightly anyone else notice this ?
Cheers for the heads up mate, have been thinking about doing this, got a few loose ends to tie up so I'll add that to the list for next weekend. What size tap did you use? Got a few spare screen bolts. Cheers
No tap I drilled a 5mm hole it's on a nice place and is easy access from under the undertray ill get some pics of the underneath tommrrow for you
Remal/Wedgiewolves have you both fitted the race style airtubes? Remal I know you have, wanted to know whether or not you unplugged the electrical connectors that were on the stock tubes from the loom when you did so? Cheers ps sorry or hijacking thread. Pics will be good of underneath mate. Thanks Dan
Yeah I used the Airtubes when pushing them into the rubbers in airbox put a bit of grease or silicone spray . spray on tubes though then push in . right one fitted nice left one was a bit of a pain wouldn't line up with opening in front so had to use a cable tie to hold in place . Yeah you can leave those unplugged mate won't throw up a light I removed solenoids Altogether There is one long thin rubber tube on left hand side leads up frame this goes to throttle bodies stick a golf tee or a bolt and cable tie .everything in front of that can be removed buddy
Yup removed air mods thing, cable tied them and but bolt in the end. No issues and just left the 2 into 1 air tube cable tied out of the way
These are the 2 fixings I done sub frame is 2mm thick really thin easily drilled and with road fairings on they are not visible
Well after a good dry day at Anglesey the fairings threw me a little prob I didn't notice until cleaning bike today .
I was wondering if yours was close bud I ain't done nowt wrong as all fixing points line up pretty much perfect so hard on the brakes all wheel gets closer anyway I might shave it out and leave it ill contact crc see what they say
Ah no gutted for that awesome paint job! Still need to drill the upper cowl fixing points before having the whole thing fitted, that's what I thought compression on the suspension under braking squishing everything closer... I'll dig out a pic of mine with belly pan fitted see how it compares.
Cheers boys paint job does not bother me it will be gravel rashed soon enough ha ha I think I will just cut the "v" out so it's exposed or let the tyre rub it away then flick a bit of paint over it
http://1000rr.co.uk/mods-upgrades-accessories-products/2209-158.htm#post146195 Not the best angle and only one pic, I really need to buy myself a drill, I'd have loads of pics then of them fitted!! Oh and get the mrs off my back about moving them out of the bedroom
Well after my tyre slightly rubbing my fairing I got my dremel fibre glass and blind luck and done a bit of bodging !!!!!!!! Now sitting back around 20mm plenty out the way gonna flick a bit of paint on it tommrrow I reckon she done
