Are SC59 exhausts interchangeable?
Discussion in 'Maintenance' started by Broadie, May 31, 2020.
  1. Broadie
    Broadie Active Member
    Hi all.
    Wondering if I can fit a 2013 exhaust on my 2009 bike. Just the silencer or the whole system? The pipe on mine is starting to look a little used as she's getting up towards 50k.
    Cheers broadie
  2. Mr_Chin_LK
    Mr_Chin_LK Well-Known Member
    2008-12 have a 51mm diameter pipe, 2013 onwards is 60mm.
    You can buy a pipe reducer adaptor though, which makes 51mm a 60mm or vice versa.
    Chin
  3. John Tuck
    John Tuck Active Member
    I don’t know the answer but you may be able to tell by looking up an after market silencer to see if they list the same one for your bike and the later one. BTW, on ebay recently there was a brand new looking std silencer listed for £100, don’t know if it’s still there - good luck!
  4. Iain
    Iain Active Member
    Mr Chin, you are nearly right, it is the 14 onwards that have the larger diameter!
  5. Mr_Chin_LK
    I stand corrected.
    Thanks for confirming this Iain.
    Note Iain's correction please Broadie. Answer is Yes 2013 will go on your 2009.
    Chin
  6. Boothman
    Boothman Elite Member
  7. Broadie
    Brilliant thank you fine chap's.
    So 14 to 16 I take it has the cat in the headers?
