Austin Racing Exhaust fitting 2012 ABS Blade Hi Heading should have been 2012....oops Got a V2 Carbon Austin Racing slip on and decat pipe. Thought I would post some pics of the fitting to a 2012 ABS Blade Finding the exhaust flap servo was quite stressful as there was nowt on the web I could find, loads on non-abs. Anyway, removed the plastics screws around the bottom section nearest the rear suspension Removing the servo wire was straightforward, long nosed pliers are my new friend, marked the servo wheel so I could return iot to its off position to avoid any error lights on start-up Old exhaust off,weighs a fair bit Link pipe, which decats the bike, Lambda sensor came out easily enough careful not to twist the wires, 2 cable ties holding it on, bit of copper slip when putting it into the new pipe. The link pipe, slip on all fit so closely, perfect fit. The clamp is nicely made. Pipe on, sound lovely, looks nice. I didn't really get a decent picture of the infill panel. It was a bastid to fit, which resulted in me telephoning Austin Racing and they talked me through the fitting as they checked one fitted to a blade at their place. Finished job I will get some more pics once I can get it outside in daylight
