baffles
Discussion in 'General 1000RR Discussion' started by D16PJM, Mar 17, 2019.
  1. D16PJM
    D16PJM New Member
    i am on a roll today, quick question, does fitting a DB killer into a yoshi make much difference, i have seen a few people say they strangle the bike but cant really see that. how much quieter are they.
    if the bike was set up with baffle out will that make a difference.
    Pete
  2. dmc12
    dmc12 Well-Known Member
    Which Yoshi have you got? I’ve got a GP Force on an RR6 and relatively recently I put in the official Yoshi baffle. Made a big difference to volume. Hard to say on power as I changed the map on the PC3 at the same time. Definitely smoother and more progressive afterwards.
    I’m planning to go stick the bike on a dyno soon and see what difference it makes baffle in vs baffle out, and also the different PC maps too. Will post once I’ve done it!
  3. D16PJM
    D16PJM New Member
    Yoshi RR7 with official DB killer, not been out on it since but it was a bitch to fit so wont be something that i take in and out so its one of the other, will be interested on your results.
    Pete
  4. dmc12
    I’m assuming the bike you’re talking about isn’t the one in your avatar?
  5. D16PJM
    D16PJM New Member
    it is the one pictured
  6. Lifeofriley
    Lifeofriley New Member
    My gpr dB killer reduces my hp by 10bhp
  7. Blade runner 1
    Blade runner 1 Elite Member
    That’s a dBHP killer. Sounds like it’s as or more restrictive than the stock exhaust.
  8. D16PJM
    D16PJM New Member
    blimey that is a lot more than i thought.
  9. Lifeofriley
    Yea it's ridiculous. Just had two maps set on the Dyno, definitely investing in a Akra or mhp.
  10. Slick
    Slick Elite Member
    The maps between a baffle and non baffled r77 are quite different especially at lower revs. I would imagine without custom mapping the power output would be greatly impacted.
