Bazzaz no runner
Discussion in 'General 1000RR Discussion' started by luke jephcote, Sep 29, 2019.
  1. luke jephcote
    luke jephcote New Member
    In a jam here after fitting a Bazzaz zfi tc systematics to bikewont start turns over did disconnect battery read some where the system has to reset its self for 30 mins after reconnecting
  2. Boothman
    Boothman Elite Member
    Hi & welcome to the forum - sorry no idea but maybe provide some details for the bike model/year as a suggestion to help any that know what you’re talking about
  3. luke jephcote
    2014 cbr1000rr turns over but not firing
  4. luke jephcote
    2014 cbr1000rr turns over but not firing up
  5. Barstewardsquad
    Can only suggest you go back over everything you added to make sure it is securely connected, and make sure you reconnect anything you had to unplug/remove to gain access etc.
    Can't remember if Honda kill switch stops it turning over or just stops it firing so could check that, or alternatively check for FI error codes on the dash.
  6. Swty
    Swty New Member
    Kill switch allows it to turn over just not fire.
