BPF oil change - 17model
Discussion in 'Maintenance' started by icedmind, Apr 3, 2019.
  1. icedmind
    icedmind Active Member
    Hi all,
    Just wondering if any of you have experience of doing a oil change on BPF.
    The question is do you need to remove the the core which hold the spring down using the special £70 open hex tool with the arm to do it or can I just leave it in place and drain the oil?
    And any idea of air gap for the 17model with the core in or is it more like a take it apart and measure and put it back the same amount job?
    Thanks
  2. Jez
    Jez Senior Member
    Hi, I made my own hex tool but I thought you may be able to get one off ebay cheaper. when all the gubbins are out it is surprising how much muck is on the parts and springs tube etc, If you are doing an oil change I would remove inners and clean. as for oil level I get 1 litre and split between the forks. it is about 500ml per leg
  3. Jez
    Jez Senior Member
  4. icedmind
    Thanks, I think I might get it sorted all together. I think mine is 43mm BPF and it said it is for 41mm tho, not sure the tube is the same in 41 and 43mm BPF.
  5. SpeedoX
    SpeedoX Active Member
  6. icedmind
    Thanks, I will give them an email.
  7. Jez
    Jez Senior Member
  8. Jez
    Jez Senior Member
    looking at reactive etc they only seem to do 1 size for on road and off road
    #8 Jez, Apr 4, 2019
