I've fitted some Goodridge front braided hoses on my 2014 model, the dual race ones with the double master cylinder banjo bolt. The hoses are rubbing on the air intake fairing when I turn the handlebars full lock, the issue seems to be not getting enough clearance with the front brake micro switch in the way. Anyone else fitted these with issues?
Is that the right kit? The caliper connection of pic three looks to be a different bend angle and inconsistent with the other caliper. Those of us who have fitted HELs etc, would usually loosen the master cylinder junction and allow the hoses to find their own place of 'free movement'.
I can’t help Unfortunately however I did notice that on dean Harrison’s tt bike the braided hoses also fouled the fairing. Is it just how race ones go?
You are right about the 3rd picture, the hose angle is different and does look odd, if I swop the ends around then the braided hose is in the way of the caliper retaining bolt meaning I cant get a socket in to remove the calipers. I've never battled with braided hoses like this before which is why I thought I would check if anyone else has fitted goodridge.
