brake bleeding 2017 abs
Discussion in 'General 1000RR Discussion' started by keithg1748, Mar 17, 2019.
  1. keithg1748
    keithg1748 Active Member
    morning all I was just wondering if anybody has changed the brake lines on these bikes as I fancy changing mine but I ive heard they are a nightmare and a garage job to bleed these brakes . so any info would be great .
  2. nigelrb
    Ooh, I wouldn't do it, but I'll be interested to see how this thread develops.
  3. Lozzy
    Agree....it'll be interesting
    When the new blades came out I asked the Honda dealer if the change back to the bosch system away from the nightmare old Honda abs would result in an easier bleed taking less time and the reply was...
    they didn't think so :rolleyes:
  4. nigelrb
    Which actually means: 'We haven't a clue.' :);)
  5. CharlieR85
    CharlieR85 Elite Member
    On a BMW with bosch ABS you need a diagnostic tool that allows you to fire the abs pump to do it properly.
  6. keithg1748
    if that's the case I think ill live with the standard hoses , lol
    , post: 486400, member: 6225"]Ooh, I wouldn't do it, but I'll be interested to see how this thread develops.[/QUOTE]
  7. CharlieR85
    The diagnostic tool for the BMW s1000's is fantastic. It's called Gs911. . you can do all sorts with it. Read and reset fault codes, reset the service counter, operate fuel pump, abs pump, operate valves, read sensor values. Really is fantastic, wouldn't be without it.
    I imagine bleeding the new blade would need the pump firing aswell to ensure you haven't got air trapped in that part of the system.
  8. Wevsky
    Wevsky New Member
    The older abs system was up to 6 hours im told,partly due to one of the bleed points involving the headers off,im reliably informed this new bosch system is 2.5-3 hours max and i see no reason why the lines cant be changed along the way,bike has to be put in certain modes and a system of steps followed,if done wrong it is start again
  9. Lozzy
    The old abs used to be about 6 but then over the years they got it down to about 3. Still a lot of money if you're having to pay Mr Honda for the fluid change
  10. Wevsky
    Wevsky New Member
    The dealer i got my bike from i took it in for its first annual service and at £78 an hour labour it wont be cheap,i will be using a independent garage who happens to be honda trained and a lot easier on the pocket
  11. icedmind
    icedmind Active Member
    I've changed my master cylinder to RCS19, it bleeds as normal but took forever to get the micro bubbles out to make it feel good, I guess it would be better if a vacuum bleeder was used.
    Service manual said bleed as normal btw.
  12. sitruc_nuahs
    sitruc_nuahs New Member
    Reviving an older thread here!
    I’m looking to get some aftermarket higher bars so obviously need to change the brake lines. Done a few brake lines before so it’s worth giving it a crack rather pay however much Mr Honda wants to charge for the bleeding?
  13. Stuish
    Stuish Senior Member
    Have you got an ABS model?
    Also, welcome to the forum!
  14. sitruc_nuahs
    I need to add a new member post!
    I’ve got a MY18 SC77 so yep, ABS!
  15. nigelrb
    Even with basic mechanical and bleeding knowledge, I wouldn't even risk it on an ABS model.
    Credit to you if you have the knowledge and patience!;)
  16. RC45
    RC45 Active Member
    The current bike requires no special consideration when bleeding the brakes.
    Per the service manual 18-6 through 18-9.
    Connect a bleed hose to the caliper bleed valve, loosen bleed valve and pump. Just like in the old days :)
    19-25 shows ABS Modulator replacement procedure with this being the final step "Fill and bleed the brake hydraulic systems (page 18-7)
