Question for a friend - will 2010 discs work on a 2006? I know the wheels are different but wasn't sure if would still work for him. If it does I can have his 06 brakes for my 05
Martin, I use 06 discs on my 05 trackbike. The thickness makes no difference whatsoever and the fixing is the same. However they are 320mm diameter as opposed to 310mm for the 05 and as such require a Brembo spacer to be fitted to the calipers. Bought mine from Demon Tweeks for around £25. I will add that, as a bonus the braking is improved quite noticeably.
My mate just wants to confirm the 10 will fit his 6, I know the front wheel was different on the 08 plus but unsure of the disc
I've bought some Brembo Serie Oro front discs for my 06 Blade and since fitted with Honda pads I've found a slight judder under hard braking. Not sure why though. Could it be the Honda pads?
