hi i just wondered that if anybody had renewed the fluid on the 2017 sp as the service manual says that this should be done every 2 years and if I can do this myself in stead of paying a dealer as ive done non abs bikes , so is it the same process. thanks for any advice.
If this is an ABS bike you can just get a tub of brake fluid and fill the master cyl .bleed through one caliper half of the bottle, then do the other just do not let the master cyl run dry, and fill carefully to not get any bubbles
