breaking 2007 RR7
Discussion in 'Parts, Accessories & Clothing' started by GH02T, Nov 7, 2018.
  1. GH02T
    GH02T Active Member
    -engine ( has had some work as 169bhp) £650
    - hpi clear silver frame £550
    -MCT forks £350
    - wheels £350 ( recent power coat and new bearings)
    - front discs £70...
    - front calipers £70
    -k tech shock £100
    -PP rear sets £100
    -PP fuel cap £40
    -brembo front master cylinder £140
    -top yoke/ risers and rental fat bars with brake lines £300
    -rear subframe £100
    - full arrow exhaust £350
    -wiring loom £50
    -rear seat £40
    - front seat £40
    Other parts available. Only thing I've sold is Speedo and ecu
  2. Muffking
    I'm interested in the front discs if you can post them for that. Do you have a photo so I can see which ones they are as I may need to dig out my spacers if they're the black ones. Where abouts are you in case collection is an option.
  3. GH02T
    GH02T Active Member
    Will.do post for £5! There black canter ones apparently off a 2010 model I've only have them on there a few weeks myself
  4. nigelrb
    Would you have a side stand at a reasonable price?
  5. GH02T
    GH02T Active Member
    What's your reasonable offer lol it dosn't have the switch
  6. jpsrepsol
    jpsrepsol Active Member
    How much for the brembo master cylinder posted
  7. GH02T
    GH02T Active Member
    I will do it for £140 posted as the leaver is damaged at the end
  8. jpsrepsol
    Sent you pm
  9. Muffking
    I'm not sure if they'll fit then as I had a set of 2008-20011 discs on my RR6 track bike, but the offset was different. So I'm currently swapping my 300mm RR4/5 discs between both sets of wheels.
    https://farm2.staticflickr.com/1940/45484497272_8797677b2b_o.jpg
  10. GH02T
    GH02T Active Member
    Hmm... well I have one 2006-2007 wheels in my bike.with oem calipers... I brought the discs a few weeks back and they fit fine on mine?
  11. Muffking
    Do they look like the on in the link I posted or do they look like these? https://i.ebayimg.com/images/g/BgYAAOSwwS1a22qj/s-l1600.jpg
    Failing that, could be worth laying one on a flat surface and measuring the offset.
    Where are you BTW. Collection may be an option.
  12. GH02T
    GH02T Active Member
    SOLD
    -ecu
    -speedo
    -speedo loom
    -brembo master
    • Optimistic Optimistic x 1
  13. Spygoat
    Spygoat Well-Known Member
    Essex, by the profile.
  14. GH02T
    GH02T Active Member
    This is what was on it but one was warped
  15. GH02T
    GH02T Active Member
    This is what I currently have on there which work and clear fine with no issues. Believe there off the newer blade
  16. Muffking
    Thanks. Those first ones are the type I need. They're the 320mm RR6/7 versions of the 300mm RR4/5 Gold ones. The one in the second photo is the 320mm '08 onwards disc. They do fit and you may not notice the difference on the road, but I found the offset meant that they were making the brakes bind on one side of my '06 callipers, no good for the track.
    • Useful Useful x 2
  17. Davo
    Davo Active Member
    I’d be interested in the engine, has it done many miles?
  18. GH02T
    GH02T Active Member
    It's just clocked 19,000 miles BUT ITS prob a bit lower as the gearing has been changed on the sprockets
  19. GH02T
    GH02T Active Member
    Bump
  20. nigelrb
    How much do you want for the side stand? I don't need the switch etc.
