Breather/Drain Tubes Query
Discussion in 'Maintenance' started by Lozzy, May 1, 2021.
  1. Lozzy
    Got my black blade back after it was stripped to find a fault which was fruitless so the bloody thing might be going :rolleyes:
    Just noticed that the 2 tubes that I believe are a breather and drain?!?
    havnt been put back where they usually go on the blades. Down and thru the hole for them in the bottom plastic belly bit.....as they are on the sp in pics 1 & 2.
    The narrower tube is in place but doesn't come out in the gap...in fact I don't know where the open end to it is. Pic 3
    The thicker tube has been fed thru at the top and has ended up on the opposite side. I tried to pull it from the correct side but wherever the end bit is its trapped. Pic 4
    I'm presuming if honda designed it for the tubes to drop vertically down and the ends to be free then there's a reason. Sorry I'm not technically minded.
    Do I need to go get them to rectify this or will it be ok as it is?
    Cheers
  2. Boothman
    Boothman Elite Member
    You paid them to do a job so it should be right
    • Agree Agree x 2
  3. SimonRR
    SimonRR God Like
    my RR5 had two breather pipes, both came down the left side and exited below the gear lever, as per your SP
  4. Lozzy
    Yep my 11 repsol did too. The tubes have always been placed like that after previous work on it....but not this time. My concern is....will their current position stop or impede them doing whatever function they do?
  5. SimonRR
    SimonRR God Like
    Not sure if it will impeed, but it should be easy enough to pull them through and route them down the correct side I would have thought?
  6. Lozzy
    Cheers Simon but I've had a......
    with it.....spoke to the dealers and I'm getting shut :rolleyes:
    • Funny Funny x 2
  7. CharlieR85
    CharlieR85 Elite Member
    The larger hose goes to the fuel tank. When you lift the tank that hose pulls itself out from where its routed. You need to remember to route it back down as you lower the tank. You might be able to hook it out and move it back to the correct side, if not you might need to lift the tank up again. The smaller hose goes to the coolant reservoir, that one has probably been dragged up a little bit by the large hose moving upwards. You should be able to get that smaller hose out and put it back down where it belongs.
  8. CharlieR85
    Whats the fault on the black bike?
  9. Lozzy
    Pm'd
  10. Kentblade
    Kentblade God Like
    Agree with @CharlieR85, the fat one is from the tank filler area and you don’t want that one getting kinked or obstructed and any build up in it.
  11. bonjo
    bonjo Active Member
    Assuming it is the same arrangement as on my RR8,
    Looks like they lifted the fuel tank and have jammed the hoses under it when lowered.
    You should have them correct it. both shold comfortable be long enoug to come out of the fairing with a 1~2 cm spare length. Or do it yourself
    You don't want neither fuel nor the fumes where there should be!
    Routing of those 2 hoses is a good indication of the quality and workmanship of the mechanic
  12. Lozzy
    Cheers for the replies but it's gone now....sold to the stealers :D
  13. hitch
    hitch Elite Member
    So what is replacing it?
  14. Lozzy
    When the 2nd hand prices come back down to a sensible level I'm looking at either a superduke 1290r/ mt10sp or tuono factory.... low mileage couple of years old :)
  15. bonjo
    bonjo Active Member
    Wish you a happy new life after cbr:)
    that’s the problem I find with products made recently. Lot’s of gizmos and showroom appeal but near impossible to service and maintain (even the dealers are usually clueless):D
  16. Lozzy
    I've still got a blade....can't see me ever not having one I love them...
    Just fancy a bit more of an upright bike for a bit. Don't fancy all the electronics though like you've mentioned :( they're wasted on me and just scream expense! But it's the way things have gone now
  17. Kentblade
    Kentblade God Like
    Shit, I’ve sold bikes when they have had issues before, but a misrouted breather hose :eek:, bet they go hide in the parts store when you walk in Loz
    • Funny Funny x 3
  18. Kentblade
    Kentblade God Like
    Even the old sit up and beg Chopper seems to have ushered in an era of electronics and we didn’t even know it
  19. Lozzy
    I do the same with blokes.....slight malfunction and offski they go ;) :D
    • Funny Funny x 6
  20. Lozzy
    Was just talking to @bazzashadow about them back in the day :eek: and how you used to get clobbered by your parents for fecking the soles of your shoes up as brakes :D
