Brembo Calipers
Discussion in 'Mods, Upgrades, Accessories and Products' started by 7belowzero, Oct 3, 2020.
  1. 7belowzero
    7belowzero Active Member
    Hi Guys,
    I am thinking of fitting the Brembo Calipers off a 2015 SP to my 2015 none SP CBR1000rr. I know they are 108mm, but will they align to the discs OK?
    Cheers!
  2. Frazzle
    Frazzle Active Member
    Two things to check.... If the SP's are Genuine M4's then just have a look at brembo site (or even a reseller, someone like omnia racing...) as you'll probably just need longer bolts (as I did with the GPRX) or possibly spacers..
  3. Frazzle
  4. 7belowzero
    Great! Thanks for the help. I am looking at the original Honda M4's with the feed in the center, as opposed to the M4's with the feed at the front. I just wasn't sure if I would need spacers or not?... Cheers!
  5. 7belowzero
    Pleased to say... all done. They fit perfect, no spacers needed as they line up with the disc perfectly and as I purchased the Honda SP Brembos, the brake lines fitted straight on.[​IMG]
  6. Saqib
    Saqib Active Member
    Looks awesome. So.. you only changed the caliper and bolts?
  7. 7belowzero
    Only the calipers, I had already changed the bolts to titanium on the original calipers and the length was the same @ 61mm.
  8. Saqib
    Saqib Active Member
    That's a bit of a result
