Brembo Floating Discs Blade 2004 to 07 08 to 16
Discussion in 'Parts, Accessories & Clothing' started by stupot, Jun 27, 2017.
  1. stupot
    stupot Active Member
    Brembo Fully floating Clubman discs to fit Honda CBR1000rr 320mm
    These discs have a 10mm offset and will be a direct fit for CBR1000rr Fireblades from 2004 to 2007.
    These discs will also fit CBR1000rr Fireblades 2008 to 2016. 08 onwards blades have a 12mm offset, I have spoken to Mode Performance (the importer for Brembo parts in the UK) and they have on the shelf the specific spacer discs for the 08 to 16 application. these cost around £5.50 each.
    If you have a Blade between 14 and 16 with ABS you will need to drill out the disc centre to allow the fitting of the ABS ring, I have been told this is a very easy job.
    The condition of these discs are excellent and are straight and true with 4.8mm thickness, 5mm from new.
    I used these on my 13 plate bike and the stopping power was fantastic. ( I don't have the spacer discs anymore)
    Looking for £250 Delivered
      File size:
      477.3 KB
      20
      File size:
      510.5 KB
      20
      File size:
      469.4 KB
      18
      File size:
      538.6 KB
      18
      File size:
      469.4 KB
      18
