Broken Swingarm
Discussion in 'Maintenance' started by ignatius, Aug 21, 2020.
  1. ignatius
    ignatius Active Member
    Last month bought my 1st blade 2010 with 3500 miles. After buying it the paddock stand bobbin on the right side was bit shaking and can see a crack. Tried to take off the bobbin and the whole thing came off leaving a big hole in the swingarm. Any advice to rectify .
  2. Saqib
    Saqib Active Member
    Ouch. Is that on one side or both sides?
    I guess it could be welded (off the bike).. however it shouldn't cost that much to buy a used swingarm and have it installed. Good excuse to do some maintenance too (chain, sprocket etc).
  3. dern
    dern Well-Known Member
    Jesus.
    Second hand swingarm from ebay would be what I'd do.
    • Agree Agree x 3
  4. Blade runner 1
    Blade runner 1 Elite Member
    Have it professionally welded by a reputable welder or buy a second hand swingarm, you could possibly pick up a second hand one for around the price of getting it welded. Either way it’s going to have to be removed.
  5. R.M
    R.M Member
    My question would be....how the hell did that happen? Any other visible damage to the bike? Has it been down the road & repaired?
    Not trying to scare monger or anything, but can't see how this would happen.
  6. ignatius
    Its just on the right hand side (Exhaust) and bought one from ebay, but looking for a more better one
  7. ignatius
    Yes, bought one from ebay , but is not satisfied and will keep looking for a better one. Bough the warrior stand to keep going for now with maintenance and cleaning
  8. ignatius
    Even i had the same thoughts , for welding or changing it needs to be taken off which is 150 pounds labour. Not sure welding can be so great without damaging the paint work or buy a second hand swingarm and swap it.My neighbor works in construction and he said he got welders on the site and will check with them. Is the swingarm alluminium??
  9. ignatius
    I did called the seller, he says might be over tightening the paddock stand bobbin. Keep trust and enjoy the ride.
    #9 ignatius, Aug 24, 2020
  10. mk3golfcab
    mk3golfcab Elite Member
    Swingarm is aluminium. Not trying to be rude but if you go down the welding route please make sure the welder is competent in welding aluminium and not just mild steel, totally different ballgame and welding ali to look good is notoriously difficult.
    • Agree Agree x 3
  11. Naz
    Naz Active Member
    I would rather have another Swingarm which you should be able to find for a reasonable price then have it welded as it won’t look to good after if it’s not done right. Wonder if that swingarm has been damaged from some previous accident. Why don’t you check with @vic_ster51 if he has anything, hes always helpful
  12. ignatius
    @Naz , definitely agree with you. Bought one on ebay, is not satisfied with that and looking for a better one. Once i get a nice one will try fixing it myself.
  13. Jez
    Jez Senior Member
    Alloy softens when heated, so a bit of a minefield welding. I would agree to replace
  14. ignatius
    Scary. Its spanking new except that hole, feel bad to throw away and as of now dont need bobbins as i have lift stand to do my maintenance
  15. Keeef
    Keeef Active Member
    The swing arm is also PU filled so contamination of TIG weld is a risk anyway.
  16. hitch
    hitch Elite Member
    I would be a bit wary of riding...does that not compromise the structural integrity of the swingarm? :eek:
  17. Slick
    Slick Elite Member
    I hear this has be fixed with noodles and super glue.o_O
    But seriously that takes a lot of force to to that, you need to be proper hench with a metre breaker bar to break that whilst tightening.
  18. Black & White
    Black & White Well-Known Member
    Are your bobbins for sale?:)
    • Funny Funny x 2
  19. Jez
    Jez Senior Member
    Swinging arm bobbins should be banned unless you have done a training course to not mark the swing arm. Then anyone found guilty of gouging out the swing arm should not be allowed a bike anymore. Rant over, Oh just one other thing keys or other crap attached to the keyring marking the tripple clamp NO, give them to the wife to mark the car door.:mad:
    • Agree Agree x 3
  20. mk3golfcab
    Never have key rings. Just the key. And my swingarm has been marked by over zealous use of a paddock stand before I bought the bike :(
