cam chain tensioner
Discussion in 'Maintenance' started by And7rp2, Jan 13, 2017.
  1. And7rp2
    And7rp2 Elite Member
    ok between Maz and I we have owned 4 fireblades from a 10 plate to 65 plate, they have all ways been over serviced, well oil changed 3000 miles or so.
    So after Honda have replaced Maz's CCT under warranty its four from four that have failed !!
    couple of things how many of you have had theirs replaced ?
    we have had them fail @
    8k on the '10,
    13k on the '12,
    15k on the other '12,
    and 3k on the '65.
    If anyone has fitted a manual adjusting CCT how often have you needed to adjust it ?
  2. ColinBR
    Yup 2 Blades 2009 and 2010. Both went at around 9k miles.
  3. PeterT
    PeterT Active Member
    2 replaced, one at 10.000 miles the other at 31,000 miles.
    Now have a manual CCT.
  4. derchef
    derchef Well-Known Member
    I have done modified tensioner springs , easy and cheap version , long lasting solution
  5. And7rp2
    Do share please.
  6. derchef
    Selling those springs since 10 years (+/-)
    Just open oem tensioner , replace the spring
    Available in two different models , for quite 80% modern honda bikes
  7. stujacks
    stujacks Active Member
    Hi Guys
    What's the issue with the cct and do I need to worry own a 2011 repsol blade with just over 10k on the clock.
    Thanks in advance Stu
  8. And7rp2
    There is a vibration/zinging noise from about 4000rpm gets worse after but usually exhaust or wind noise takes over above 5000rpm. Almost as if the fairing is loose. Maz has got a racefit exhaust ( kin loud ) and she felt/heard the noise.
    If that's what you mean by issue ? But ultimately if left cam chain can slip/ jump teeth and that's goodbye engine internals !!
  9. stujacks
    Hi
    No noise or vibration on mine,so do I need to be thinking of changing the cct.
  10. And7rp2
    Wait till it's making a noise or vibing , just don't leave it too long before replacing cct
  11. Cbrjay
    Cbrjay Well-Known Member
    I've had the manual one in 600rr for years and never had to adjust it
    • Downvote Downvote x 1
  12. Mr OCD
    Mr OCD Well-Known Member
    Anyone know how to diagnose it?
    I've got a slight rattle after I've blipped the throttle - you can hear it as the revs come down... suspect exhaust baffle but did wonder if it could be CCT.
    2010, 27k miles
  13. Cbrjay
    I'm sure that's how mine started on Cbr600rr
  14. Mr OCD
    Worth noting this is in neutral when standing next to the bike. No vibration / buzzing when riding.
  15. TheRamJam
    TheRamJam Well-Known Member
    I have a RR-9 bike coming up to 8k miles on her
    I might do this mod just to stop me worrying about it.
    So which part do I need and is it quite easy to do?
    Cheers
  16. Cbrjay
    Think I only noticed mine when blip/rev engine at stand still when revs was dropping
  17. Cbrjay
    Not sure on blade but 600rr was easy job, I just worried setting it up. But it was easy to do. I put mine on about 12000miles ago and a lot of track days and never had to adjust it after 1st set up
  18. Mr OCD
    Cheers. Will keep an eye on it.
