can anyone help
Discussion in 'General 1000RR Discussion' started by Mark123.7276, Jul 29, 2015.
  1. Mark123.7276
    Mark123.7276 New Member
    Hi there please can you help I have a cbr1000rr 04 . I went over a speed hump a bit fast every thing seemed ok I got of the bike went into a shop but when I got back on the bike it turned over but wouldn't fire up . Can you help please.. . I left the bike over night tried starting it and it started 1st time but it ticks over for about 10seconds then stops dead. Then it wont start unless I leave it for a bit then does the same again. The revs go up a bit then drops stopping dead instantly. Thank you every one for your help seems to be running ok now
    #1 Mark123.7276, Jul 29, 2015
  2. Abb
    Abb Active Member
    Hi Mark, this is not a wind up, bug have you checked the position of the kill switch? It's just I fell foul of this recently, my last bike (Suzuki GSXR) would not do anything if the kill switch had been pressed, however l noticed on the blade, it actually allows the engine to turn over but not fire!
    You never know..
  3. Mark123.7276
  4. rb1000rr
    rb1000rr Active Member
    Is it turning over at normal speed or faster than normal also was it possible to bump start
  5. Nytol
    Nytol Active Member
    Lol, I had this tonight, must have accidentally knocked it somehow when I put it away yesterday, I was sitting on the drive wondering WTF was going on, until I wondered if the switch had been flicked, and it had :D
  6. Lozzy
    Lol same as when some clever tw#t knocks it off as you're turned the other way chewing the cud at traffic lights & you're left with a durrrrr look on your face as your mates rofl off into the distance :D
  7. Mark123.7276
    It seemed to be normal speed and no it wouldn't bump . It's exactly the same as if the kill switch is switched but its not
  8. RRoss
    RRoss Active Member
    Does the blade not have some sort of tilt switch that shuts the fuel off mounted in the nose cone? Maybe it came loose with hitting the speed bump and then moved further when you parked at shops?
  9. Mark123.7276
    I see somthing about a bank angle sensor .
  10. Mark123.7276
    Hi . I left the bike over night tried starting it and it started 1st time but it ticks over for about 10seconds then stops dead. Then it wont start unless I leave it for a bit then does the same again. The revs go up a bit then drops stopping dead instantly.
  11. garyauk
    garyauk Active Member
    This to me, sounds very much like loss of fuel pressure
    can you here the pump running running?
  12. Mark123.7276
    Don't think so but then I don't no if I ever have done . So not to sure what it sounds like .
  13. Kevin1
    Kevin1 Elite Member
    Jase had a similar problem with his track bike. It turned out to be the lean angle sensor. Maybe the speed humps has put it out of kilter. This sensor kills the engine if the bike falls over.
  14. Mark123.7276
    . Do you no where the sensor is
  15. Mark123.7276
    Cheers. Do you no where the sensor is
  16. Kevin1
    Kevin1 Elite Member
    I'm afraid not. Hopefully either jase or a mate of his will see this and ask him.
    #16 Kevin1, Aug 2, 2015
  17. Mark123.7276
  18. Kevin1
    Kevin1 Elite Member
    I have sent him a Facebook message but I don't know if jase uses his account much.
  19. Mark123.7276
    Thank you
  20. Muffking
    It's right in the nose cone, butted up against the headlight. You may be able to see it with the screen off, but I'm pretty sure it's a nose off job to remove.
