CBR 1000rr change +MPH/KM
Discussion in 'General 1000RR Discussion' started by jack, May 12, 2018.
  1. jack
    jack Active Member
    How to change +MPH/KM on clock CBR 1000rr 2010
    I try this and it does not work on my one
    1.Turn the Ignition switch ON
    2.Press and hold both control button A and B (A is the top button) for more
    than 2 seconds.
    3.Press control button A to select miles/gal or km/l
    4.Press control button B
  2. nigelrb
    Hi Jack. You might know from the Owner's Manual that this facility operates only on 'E, III E, and VE only'.
    Is it possible yours might be an import from France or Europe?
  3. jack
    jack Active Member
    Yes the clocks is import from Europe
  4. nigelrb
    Ok, that means that you can't change it. Ref: CBR1000RR-RA QOwner's Manual at page 20. (I have a 2011, by the way)
  5. jack
    jack Active Member
    Ok thank you. Is there any way to change it?
  6. nigelrb
    Not that I am aware of. Best advice would come from a dealer I imagine.
    There seems no real logic why Honda would do that, unless they believe there is no likelihood of owners needing to change from metric to imperial in the Euro Zone. However, the owner of a French build cannot, according to the manual, change from kilometres to miles after crossing the Channel to England. Weird.
    What do you actually need to change on yours?
  7. jack
    jack Active Member
    I need to change from km to mph.
    I will try maybe people who are doing a meter correction,what do you think?
  8. Nic Miles
    Nic Miles New Member
  9. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
    Some clocks have the option to change it, some don't. If your clocks don't have the option, you can only do it by buying another one,
  10. BikersDiscountStore
  11. morpheus20170
    morpheus20170 Active Member
  12. nigelrb
    Wow!
    Just scored a downvote for perfectly concise information in post number 2.
    I am absolutely positive that member @Sp0oner would not do this on purpose.
    This highlights what I have always maintained: moderators ( @sps170373 ?) should re-evaluate this function, OR simplify its use for mobile devices.;)
  13. Barstewardsquad
    Now now @nigelrb don't go starting all that off again. If it was a mistake I'm sure it will be retracted, if not then so be it. Theres too much PC namby pampbyness around as there is.
    PS feel free to downvote this if it make you feel better :p
  14. nigelrb
    That's part of my point BSS, that the downvote is often used as vengeance or retribution. I would not downvote you or anyone for expressing opinion.
    If I have a disagreement with any post, most know I would raise it in text rather than by the click of a mouse. The proof is in the pudding so to speak. My member 'stats' verify that I have not made one negative vote against any member.
  15. Sp0oner
    Sp0oner Active Member
    Sorry Nigel didn’t even know i’d done it so glad you mentioned me in your post to alert me and i’ve rectified it now!
  16. nigelrb
    No probs for me, and the reason I tagged you because I knew it was accidental. ;)
  17. Sp0oner
    Yep on my ipad so must have caught it whilst scrolling down :rolleyes:
  18. sps170373
    Unfortunately I don’t have the access or privileges to change the functionality of the site, but yes the downvote button does need repositioning due to people’s chubby fingers when scrolling
  19. nigelrb
    Whoops. That's not a sarcastic thanks, it's thanks for your response and acknowledgement.;)
