CBR1000rr 08-16 Parts Clearance
Discussion in 'Parts, Accessories & Clothing' started by vic_ster51, Feb 20, 2018.
  1. vic_ster51
    vic_ster51 Active Member
    For sale i have the following parts i need to clear.
    Prices inc postage to mainland UK
    If doesn't state bike year then it fits all years 08-16
    Front brake calipers in black (two sets - ie 2 pairs) - £90
    Front braided lines with bolts - silver-clear braided 2 lines - £25
    Rear caliper x 2 - £15
    Rear caliper bracket x 2 - £10
    Pair of 12+ style wheels only in black - £650
    Brand new OEM 12+ style rear wheel in black - £250
    Rear swingarm, black - £50
    OEM exhaust headers - £45
    Big piston 2012 style rear shock x 2 - £120
    Front headlight wiring loom - 08-11 - £30
    Standard rearsets Left and right complete brake lever etc - £45
    Standard rearsets left and right just hangers - £20
    Standard brake lever - £10
    Standard clutch lever - £10
    Clutch cable - £10
    Sprocket cover x 2 - £10
    Set oem radiator hoses and clips - £25
    Sprocket carrier x 2 complete - £30
    Rear passenger pegs - £20
    Rear light - red - £15
    Rear light clear - £20
    Bottom Yoke x 2 - £30 and £50 one as marks
    Top yoke x2 - £45
    HRC battery tray new - £25
    Front axle - £15
    Rear axle - £15
    Ignition Coils all 4 (i have 2 sets) - £50
    Sidestand x2 - £30
    Various 2012-16 plastic trim panels all oem
    2012-16 airducts left and right, £50 or £30 each
    Various 08-11 oem plastic trim pieces
    Front brake master cylinder - £40
    Clipons oem left and right - £50 or £30 each
    Complete main wiring loom 08-11 - £40
    OEM as new front brake discs - £120
    Rear subframe - £200
    Clutch perch - £10
  2. PauloHRC
    PauloHRC God Like
    Hi do you have an 08-12 hugger amongst the plastics??
  3. vic_ster51
    I do i think... but from honda new they are like £15 brand new
  4. PauloHRC
    PauloHRC God Like
    Oh right, thanks for that, it's going in tomorrow for a check over so I'll see if they can stick one on.
  5. TheRamJam
    TheRamJam Well-Known Member
    Whats the rough mileage in the rear shock?
  6. vic_ster51
    Hi, very low, clean no marks rear shock. Removed for trackbike build from 16 plate
    Only 2,000km
  7. TheRamJam
    Don't suppose you have any pictures of the shock. Trying to think if my existing Honda hugger will fit the new BFRC unit. Not sure.
  8. vic_ster51
    What hugger you running?? Its fit tight with 08-11 honda racing carbon hugger and will rub... if you have standard hugger it wont fit 12+ new from honda only £15
    Aftermarket huggers vary if you look at how much room there is from your hugger and shock res etc and if there is reasonable amount you will be fine
  9. TheRamJam
    I have a non carbon Honda racing rear hugger.
  10. vic_ster51
    08-11 one? They fit better than carbon one as have bit more flex and size. I had one of these shocks and a 08-11 repsol hugger and it fitted fine, it just rubs on the shock res slightly but this is covered up anyways so cant be seen
