Cbr1000rr 08 gearbox problem
Discussion in 'New Members' started by Yea13ucidy, May 2, 2016.
  1. Dave
    Dave Member
    Should'nt take long to sort, budget allowing.Should only take a day to pull gearbox out and replace with another. Fortunately the gearbox is of the cassette type and you don't have to drop the motor, assuming it's the same set up as RR5.;)
  2. ColinBR
    Nope. Totally different on the 08 onwards bikes mate. You have to split the engine to replace the gearbox.
  3. ColinBR
    Forget the Haynes manual mate.
    What u want to do is have a look on here in the maintenance thread and get the workshop manual download.
    It goes into a lot more detail than the Haynes ever will.
  4. Dave
    Dave Member
    Well there's progress for you, taken a step backwards.:confused:
  5. Yea13ucidy
    Yea13ucidy New Member
    Engines out but what size flywheel puller do I need is it 20 MM. Does anyone know cheer guys doesn't say in the Haynes also anyone got a link for a workshop manual thanks again if you can help
  6. ColinBR
    It's a special thread to be honest mate. I didn't have to remove mine as I was splitting the whole engine.
    I'm sure there is a workshop manual in the maintenance thread
  7. ShinySideUp
    ShinySideUp Elite Member
    If the same crank is going back in don't bother removing the stator flywheel, the cases will split and the crank will happily come out with it still attached.
  8. Dave
    Dave Member
    The thread on the RR5 is M20, the pitch is 1mm or 1.25mm:rolleyes: could check it for you if need be but as shiny says no need to remove it;).
  9. Yea13ucidy
    Yeah it's a m18 1.5 puller but looks like it can stay on just got to split the engine now but it's on hard lol any tips anyone can give me on splitting the crank case here's a picture on the gear lol
  10. ColinBR
    Make sure you have all the bolts out mate. We found 2 or 3 hidden bolts when trying to split the engine. Was a bit of a pain to locate them all but once done a few taps with a rubber mallet seen it come apart.
  11. Yea13ucidy
    Found the sneaky hiding bolt lol crankcase came off with ease I've ordered 3rd gear 3rd/4th and forth plus upper and lower gaskets £256 USA over £500 in the uk but of course custom will be a bit but still cheaper then this Country soon the fun begins putting her back together keep you posted ;)
  12. Yea13ucidy
    Starting to appreciate the awesome engineering gone in to produce Such powerful engine mental stuff
  13. ColinBR
    Yea I enjoyed stripping mine down too. Didn't actually take that long when the engine was on the bench
  14. Yea13ucidy
    Yeah I was surprised how quick we did it garage wanted £1000 just to be where we are at now took us 7 hours so far which it bad starting to regret putting all the bolts in one tray tho ...only joking all neat and tidy I promise :D Honda garage said it would take 2 days I don't believe it myself I just proved them wrong and we haven't got half the kit they got rip off merchants
  15. ColinBR
    Yea I wouldn't pay anyone for that work. It's easy enough and you get to see how it all goes together.
  16. Yea13ucidy
    Fascinating stuff some clever people out there
  17. Yea13ucidy
    What's the best thing to clean up my exhaust I've heard oven cleaner anyone got any suggestions
  18. ColinBR
    Autosol
  19. ShinySideUp
  20. Dave
    Dave Member
    What caused the gearbox to fail in the first place, do you know?:confused: Like you we have ordered engine parts from the USA amazing how much cheaper they were.
