Cbr1000rr 08 onwards parts for sale
Discussion in 'Parts, Accessories & Clothing' started by vic_ster51, Jun 25, 2021.
  1. vic_ster51
    vic_ster51 Active Member
    Few parts I have to go...
    3spoke front wheel black 08 16
    £185
    08 11 pair oem air ducts had flapper mod done £40
    12 16 pair oem air ducts had flapper mod done £60
    08 16 radiator oem and fans £80
    Oem clock bracket 08 16. £55
    Pro mach rearsets in black race shift 08 19 £145
    08 11 clocks, speedo 19k on miles £150
    08 11 front wiring loom £35
    Fuel pump 08 19 £55
    Fuel tank 08 13 £65
    08 11 style front forks fit 08 19 non abs k tech piston kit, adjusters and springs etc £500
    Oem kill switch 08 16 £20
    Oem left switchgear 08 16 £30
    Bottom yoke silver 08 19 £65
    Motoholders front race bracket 08 16 £95
    Injectors, throttle bodies 08 16. £50
    Axles, rear calipers, full loom etc etc
    And more please ask
  2. phil
    phil Active Member
    It the tank stright and still for sale? If so I'll have it
  3. vic_ster51
    PM sent
  4. Pauliealdridge69
    Pauliealdridge69 Active Member
    Nice standard exhaust tucked away 08 onwards?
  5. vic_ster51
    Sorry no. Sold my last 1 I had
  6. Pauliealdridge69
    Cheers
    I’ve found some really tidy 14-15 plate exhausts but you were saying they won’t fit. Is it the hanger mount or something small different? I’m studying the pictures and can’t see any difference. I’m sure when it was new it had one without a cover on the side. But eBay has some with covers and some with out listed over all the years lol.
    There’s a nice SP one that’s a 15 plate but it also has the cover on it. I do remember the 12-13 had different shape Yoshimura cover panel, so thinking I may need one with out cover on the lower face. Cheers for any help vic
  7. vic_ster51
    Basically - 08-13 years have 50mm headers.... 14 onwards have 60mm. This is why they dont fit, unless you make a spacer etc. Regardless of what people might say on ebay. The above is correct
    Or another option is just buy said header from whatever year range you need to fit onto
  8. Pauliealdridge69
    That’s why I needed.
    I can happily whip a spacer up on the lathe if needed so perfect thank you.
    Did you have any tidy rear indicators. Mine have electrical tape round the arms so guessing broken underneath! I’ll
    Peel tomorrow thanks again
  9. vic_ster51
    I do actually, have a nice pair oem rear indictors with good mounts and wiring with oem connectors etc
    £30 posted Send me PM
  10. BladeOfGlory
    BladeOfGlory Active Member
    @vic_ster51 do you have any of the rubber bits that go around the air ducts? I don’t even know what they’re called haha
    That go here:
  11. vic_ster51
    Hi, sorry i dont, sold last pair i had
  12. BladeOfGlory
    No worries, do you know what the part number is for them?
  13. vic_ster51
  14. BladeOfGlory
