CBR1000RR GPR STEERING DAMPER 2008 - 2016 - FULLY REBUILT
Discussion in 'Parts, Accessories & Clothing' started by brg1000, Jul 29, 2020.
  1. brg1000
    brg1000 Active Member
    This GPR steering damper has just had a full nut and bolts rebuild and re oiled as you can see from the pictures. All the seals were replaced as well as fresh oil and so the damper is pretty much as good as new. Cosmetically its in really nice order with no scores or scratches of note.
    It comes with the fitting instructions but the resistor for the HESD is missing. Its a simple fix. get a 5 watt 10 ohm resistor and short the connections into the plug that you will remove from the factory damper.
    These dampers are really very good and they will give far superior performance to the factory HESD damper.
    £199 or near offer. Paypal is good.
  2. Cavman
    Cavman New Member
    Hi mate, has this sold? Thanks
