CBR1000RR OEM New (Take-offs) & other parts
Discussion in 'Parts, Accessories & Clothing' started by KPH, Dec 15, 2018.
  1. KPH
    KPH Active Member
    I'm selling all the parts listed below, will likely fit 08-16 fireblades (except the wiring looms)
    New items were removed from a new 2012 CBR1000RR that was converted to a race bike.
    Some items for a Z1000 in there, and also some generic spares.
    If more photos are needed, please send me a message and I can email photos
    Postage will be priced at cost, depending on the package size/weight.
    1 CBR1000RR 1 x pair Front Calipers – Tokico New (take-off) £150
    2 CBR1000RR 1 x pair Front Discs – Standard New (light use) £110
    3 CBR1000RR 1 x pair Front _Discs – SP New (take-off) £110
    4 CBR1000RR Front master cylinder & Hoses New (take-off) £75
    5 CBR1000RR Rear Caliper (nissin) New (take-off) £45
    6 CBR1000RR Rear Hose New (take-off) £15
    7 CBR1000RR 2 x Rear Discs New (take-off) £35 ea
    8 CBR1000RR Rear Caliper Bracket New (take-off) £45
    9 CBR1000RR Rear master Cylinder & Hose New (take-off) £50
    10 CBR1000RR Steering Damper New (take-off) £200
    11 CBR1000RR Air Filter New (take-off) £15
    12 CBR1000RR Air Funnels set (4pcs) New (take-off) £40
    13 CBR1000RR Air injection Control Valve New (take-off) £50
    14 - - -
    15 CBR1000RR Clutch lever New (take-off) £10
    16 CBR1000RR 1 x pair Footpegs & gear/Brake Lever New (take-off) £175
    17 CBR1000RR Fairing & Seat Set New (take-off) TBC
    18 CBR1000RR Windscreen New (take-off) £50
    19 CBR1000RR Ignition & Fuel Tank Lock (Key Set) New (take-off - small nick during removal) £250
    20 CBR1000RR Front Light New (take-off) £185
    21 CBR1000RR Rear Light New (take-off) £50
    22 CBR1000RR Front Fairing Bracket New (take-off) £50
    23 CBR1000RR Rear Hugger New (take-off) £10
    24 CBR1000RR Rear Subframe New (take-off) £225
    25 CBR1000RR Rear Shock (Showa Big Piston) New (take-off) SOLD
    26 CBR1000RR Radiator Fans New (take-off) SOLD
    27 CBR1000RR Radiator overflow canister New (take-off) £25
    28 CBR1000RR Exhaust/Headers New (take-off) £150
    29 CBR1000RR Exhaust/CAT New (take-off) £150
    30 - - -
    31 CBR1000RR LHS Switch gear New (take-off) £65
    32 CBR1000RR Wiring Loom Used, good condition £225
    33 CBR1000RR Dash New (take-off) £415
    34 CBR1000RR Servo motor New (take-off) £50
    35 CBR1000RR – HRC Wiring Loom & ECU (2008-2011) Used £350
    36 CBR1000RR – HRC Water Bottles Used £10
    37 CBR1000RR – HRC Water hose Blank (Billet & Samco Hose) New £48
    38 CBR1000RR – Bazzaz fuel commander & loom Used, good condition £150
    39 CBR1000RR – Bazzaz Z-Bomb Used, good condition SOLD
    40 CBR1000RR – Dyno Jet 3 & HM/TKRP Quick shifter Used £275
    41 CBR1000RR – HM Dash back plate 2008 – 2011 New £25
    42 CBR1000RR – Skutz servo eliminator Used, good condition SOLD
    43 Brembo GP4 RX 108mm Front Calipers w/ EBC GPFAX Pads & 84mm Rear (nickel finish( Caliper Used, good condition SOLD
    44 CBR1000RR EBC GPFAX Tokico Pads New £50
    45 TWM Front Brake adjuster New £50
    46 Goodridge Speedbleed caliper nipples (2PCS) New £10
    47 CBR1000RR – FP Racing Rear caliper under-slung bracket Used, good condition £125
    48 CBR1000RR – Motoholders / TKRP rear Subframe w/Alu plate Used, good condition £225
    49 CBR1000RR – TKRP Seat Foam New £20
    50 CBR1000RR Arrow WSBK exhaust Used, good condition £750
    51 CBR1000RR Lightech rear lifters New, unpackaged £23
    52 Z1000 1 x pair Rizoma Footpegs New, unpackaged
    53 Z1000 Akropovic Slip-on & Dominator De-Cat Used, good condition £750
    54 Oxford Visor bag Used, good condition £11
    55 Diamond Tyre Warmers Used, good condition SOLD
    56 Renthal Clip-ons (CL100) New £85
    57 PSR Drain bolt New £20
    58 DZUZ Woodcraft Quick-Release Fasters (6pc) New £20
    Edited for quantities and rear brake disc price
    CBR Tokico Front Caliper 01.jpg CBR Std Discs 01.jpg CBR Front Master.jpg P_20181208_144220_vHDR_Auto.jpg CBR Rear Brake Hose.jpg CBR Steering Damper 01.jpg P_20181208_175752_vHDR_Auto.jpg CBR Air Injection Valve 02.jpg P_20181208_175604_vHDR_Auto.jpg Foot Pegs-02.jpg
    #1 KPH, Dec 15, 2018
  2. KPH
    KPH Active Member
    More thumbnails
    Rear light.jpg Front Fairing Bracket 02.jpg Air Duct Flap Valve 01.jpg CBR Rear Hugger 01.jpg CBR Radiator Fans 02.jpg Rear Subframe 01.jpg CBR Showa Rear Shock 01.jpg Radiator Overflow 01.jpg Exhaust 04.jpg Light & Indicator switch 01.jpg
  3. KPH
    KPH Active Member
    More thumbnails
    CBR Standard Loom 01.jpg P_20181208_174706_vHDR_Auto.jpg HRC Water Bottles.jpg P_20181208_152157_vHDR_Auto.jpg P_20181208_180231_vHDR_Auto.jpg P_20181208_180323_vHDR_Auto.jpg P_20181208_180351_vHDR_Auto.jpg P_20181208_173347_vHDR_Auto.jpg CBR Brembo GP4-RX Callipers 01.jpg P_20181208_152114_vHDR_Auto.jpg
  4. KPH
    KPH Active Member
    Yet more thumbnails
    EBC GPFAX Tokico pads 01.jpg P_20181208_152402_vHDR_Auto.jpg P_20181208_144136_vHDR_Auto.jpg CBR Rear Brake Bracket 01.jpg CBR Rear Brake Bracket 07.jpg Seat Foam 01.jpg CBR Arrow Exhaust 01.jpg Lightech Rearlifts 01.jpg P_20181208_124051_vHDR_Auto.jpg IMG_20161019_231550.jpg
  5. KPH
    KPH Active Member
    Final thumbnail message
    Renthal Clipon CL100 01.jpg Renthal Clipon CL100 02.jpg PSR Oil Bolt 01.jpg PSR Oil Bolt 03.jpg P_20181208_143921_vHDR_Auto.jpg Z1000 Akropovic Slipon & DeCat 01.jpg
  6. Demmel
    Demmel Member
    Brembo rear caliper price? not found on the list
  7. KPH
    KPH Active Member
    it's in with #43 with the front calipers.
  8. Demmel
    Demmel Member
    Sale only kit?
  9. KPH
    KPH Active Member
    Yes, two fronts and one rear.
    If I don't sell the front and rear calipers, then I will use both next year.
    • Friendly Friendly x 1
  10. kevin nichol
    kevin nichol New Member
    Will take the Simons tyre warmers if in good working condition and are superbike size. Msg me payment details
  11. Lifeofriley
    Lifeofriley New Member
    Hi mate I will take HRC coolant bottles. You got hoses for them? Also what's best price on left side switch hear. J
  12. 010967djg
    010967djg Active Member
    Hi not seen them listed but thought id ask do you have the mirrors?
  13. Mark1
    Mark1 Active Member
    If not I have got a pair of immaculate ones
  14. KPH
    KPH Active Member
    They have been sold.
  15. aaron
    aaron Active Member
    Interested on discs, do you have 2 sets available?
  16. KPH
    KPH Active Member
    I have a set of standard discs and a set of SP discs. The only difference is the colour of the inside carrier/spider. If you need more photos of them, message me your email address please & I'll email this evening.
  17. aaron
    aaron Active Member
    Hi, sorry for the long delay, email is [email protected], please send a few pics when you can, also can you confirm they were removed from a zero mile bike
  18. Blade07
    Blade07 Active Member
    Hi, is the rear hugger still available. How much would it be posted to Norwich.
  19. KPH
    KPH Active Member
    Yes, the rear hugger still available. P&P would be £ 4, but it could only be posted after 12th Jan.
  20. KPH
    KPH Active Member
    I've just photo'd and emailed the pics to you.
