Chain cleaning
Discussion in 'Maintenance' started by Madmackie, Sep 14, 2016.
  1. Madmackie
    Madmackie New Member
    Can anyone advise the what is the best to clean and degrease the chain and sprockets before I re grease was thinking petrol or brake and clutch cleaner or am I mad thx
  2. wurzel
    wurzel Active Member
    Paraffin. Easy and cheap
  3. Remal
    As above 100%. used it on all my bikes and now my current bike . Never been a issue
  4. Rids666
    Rids666 Active Member
    I used paraffin on my bike. When I picked it up the chain was a real mess but I got it from this....
    Bought the paraffin from homebase. Poured some into an old coffee jar and then clean it using an old toothbrush.
    Really was a doddle to do.
  5. bonjo
    bonjo Active Member
    I tried the sprays. they are ok as a "lick and a promise" method but pricey and doesn't get your chain cleaned like in the picture frpm ridds.
    paraffin, white spirit. I use kerosene, guess diesel would be similar, both cheaper than paraffin but you need to be careful not to get it on tyres, footpeg, brake disc and gear selector although a food foam wash with muc off will clear it
  6. Madmackie
    thx all used a brush cleaner as I had it in the garage came up a treat
  7. Great Guy
    Great Guy Well-Known Member
    Paraffin from B&Q.
  8. Great Guy
    Take the sprocket off and clean with emery paper, or buy a gold one; looks a lot better
  9. Rids666
    Job for the winter ;) just goes to show though what can be achieved with paraffin, a toothbrush and half an hours elbow grease
  10. Sean M
    Sean M New Member
    Got any pics of your before and after ?
  11. rewy..rr
    rewy..rr Active Member
    Got to agree with the tooth brush and paraffin, just cleaned mine using paraffin looks good and cheaper than a lot of chain cleaners.
  12. Billalrebhan
    Billalrebhan New Member
    Always use wurth brake and chain cleaner and a cloth, then wurth high performance chain wax, both great products been using them both for over 10 years and never had a problem
