Changing the end can on an RR5 - how?
Discussion in 'Maintenance' started by Sp0oner, Sep 16, 2019.
  1. Sp0oner
    Sp0oner Active Member
    Currently have a Yoshi RS5 and thinking of replacing it with an Arrow. Being under the rear seat it is more work than i've had to do before with side mounted cans which are normally just a couple of bolts.
    Do I have to take the rear plastics off or can it be done without doing that? Clearly as i'm asking this i'm pretty useless with bike DIY so any instructions would be very much appreciated!
    Also anyone know if the Yoshi cans use the original pipe so the Arrow will be a straight replacement?
  2. AndrewQ
    AndrewQ New Member
  3. Jez
    Jez Senior Member
    If you are not getting it mapped I would also do an ECU reset after fitting , I think you start the engine do not touch the throttle, wait til the fan kicks in then stop with the kill switch. This will then tell the ECU to learn the new fuelling for the can
  4. Sp0oner
    Thanks for the replies :cool:
