Charging circuit advice needed
Discussion in 'Maintenance' started by DrWeezergood, Mar 1, 2019.
  1. DrWeezergood
    DrWeezergood New Member
    Greetings.. 2004 blade, new battery fitted but charging circuit not working. 12.5 volts at battery terminals no change when bike rpm increased. Start bike, run for 5 mins, stop, try to start again, not having it. Have run all the workshop manual checks on regulator, all check ok. Same with the stator all read as ok. At a loss now so any advice would be welcome.
  2. Boothman
    Boothman Elite Member
    Check for continuity between the frame/battery terminals/stator etc components - sounds like a broken/disconnected wire somewhere
    • Agree Agree x 2
  3. DrWeezergood
    Ok will check..thanks for the reply
  4. red5
    red5 Well-Known Member
    Have you done a dynamic test of the stator?
  5. sulaco
    sulaco Active Member
    I've posted this here before it covers testing stator reg/rec:
