Clutch Fluid Bleed
Discussion in 'Maintenance' started by Hudson, Apr 18, 2015.
  1. Hudson
    Hudson Active Member
    Hi,
    Can anyone guide me to where the bleed nipple is for the clutch to be bleed and new fluid put in.... oh i have a Honda CB1000R 2010 so i guess it will be the same as the 2007 blade ?
  2. Barstewardsquad
    On the 07 the bleed nipple is on the slave cylinder, just above the front sprocket.
  3. Muffking
    And the fluid is in a small reservoir on the left bar.
  4. Hudson
    Thanks for that.
  5. exuptoy
    exuptoy Elite Member
    Don't quote me but I'm sure my 08 has a cable clutch.
  6. madmac
    madmac Well-Known Member
    Yeah the 08 onwards is a cable clutch so...... :confused:
  7. Barstewardsquad
    08 CBR1000RR is a cabled clutch, but that is not what we are talking about here ;)
  8. exuptoy
    Ah, never noticed CB1000R not CBR100RR ;)
  9. madmac
    Ah - glad I'm not the only one who can't read good... :D
    • Funny Funny x 2
  10. ccr32
    ccr32 Active Member
    Why did Honda change back to a cable clutch after '08? Always assumed that a hydraulic clutch is better and therefore 'progress'...
  11. exuptoy
    Customer feedback, cost, feel........who knows? The HC that was fitted to my old Exup 1000 RU was like a switch. It was a bastard to slip when you needed to.
  12. sp1n99
    sp1n99 Active Member
    Less weight, less maintenance, more feel.
  13. Dave
    Dave Member
    Changed back to cable on cost grounds, cheaper to produce.;)
