Custom Tool
Discussion in 'Maintenance' started by Swiss T, Feb 26, 2014.
  1. Swiss T
    Swiss T Active Member
    Can anyone make this for me?
    Its a 8mm ring spanner (just the ring bit) welded at 90 degrees to a 400mm long T-Bar.
    Its a tool which, in theory, can be used to reach the bleed nipple on the abs front power unit, without the need to remove anything except the left mid fairing. I understand that on 2012 models onwards, it could be passed through the gap in the fairing.
    I have the hose which would be pushed onto the nipple using long reach (400mm) offset pliers.
    Just a thought.
  2. Kentblade
    Kentblade God Like
    From adversity comes forth ingenuity.....love your thinking :)
  3. Slick
    Slick Elite Member
    Wondering if it would be easier to route a metal brake hose from the nipple to an area that is accessible.
    Obviously needs to be done right though, don't want that bad boy working it's way loose!
  4. Si.
    Give megawatt a pm Tony.
  5. Swiss T
    I think I have it lads. I have ordered an 8mm crows foot socket spanner which fits a 3/8s extension; hoping it does the trick.
