Daft question about keys
Discussion in 'General 1000RR Discussion' started by Robbie, Feb 2, 2021.
  1. Robbie
    Robbie Active Member
    Hi all this might be a daft question, but I have a 2013 fireblade, I have 2 keys and one is bent, is there any issue in using the other key?
    I know sometimes the other key is the master key for alarms/immobiliser, but not sure there is one on my bike.
    Any help would be appreciated
    thanks
  2. Empty_Ten
    Empty_Ten Member
    I don’t believe there is a master key for that year’s blade.
    I too had a bent key for my blade, I just kept using it haha. If you want to crack on and use the spare key then I don’t see why you couldn’t.
  3. Fatboy
    Fatboy Active Member
    You could always buy a chipped blank key and get it cut and "cloned" to the one you have, the ECU will take up to 4 different keys but by cloning you use the same key and make as many as you want, dont take it to a dealer though ,they will charge you the earth just for another key, I had 3 more made for my 929 , keys and from chips China and a local key cutter to clone it for me , cost £20 all in
  4. Coops74
    Coops74 New Member
    How do you get it cloned? I would like to do this as only have one key at the min.
    And yea you are right I asked the dealer how much they charge, daylight robbery.
  5. Coops74
    Coops74 New Member
  6. Fatboy
    Got mine done by a local Mobile Locksmith, he actually ordered the cloning machine that I got the Key and chip from on Aliexpess, he cut the key then cloned it, could look in your area for Locksmith's (Motorcycle) and try from there.;)
  7. Coops74
    Coops74 New Member
    Thanks mate ill have a look into it :)
  8. hitch
    hitch Elite Member
    Depending on how bent the key is....try crushing back to flat in a vice.
    I did this with a previous bike key and it worked a treat, the key was more twisted than bent but a good beasting in the vice sorted it.
  9. bonjo
    bonjo Active Member
    hitch's suggestion is my first course of action!
    Both key (as on my RR8) are interchangeable.
    Worth mentioning that I annually swap keys on my car and bike so that the ignition/ lockbarrel and the key wear in tandem. I have heard situations where a brand new key does not turn the lock!
  10. cronester
    cronester Active Member
    I had the same problem with my CBR929 a few years back so I carefully removed the transponder from the bent key and put it into a new blank and used araldite to seal it up. Worked perfectly.
  11. Ian E
    Ian E Active Member
  12. Coops74
    Coops74 New Member
  13. Paul Longstaff
    Paul Longstaff Active Member
    Love it are you from the North east by any chance?
    Haven't heard that for ages :D
  14. Coops74
    Coops74 New Member
    East Midlands bud:D
  15. Paul Longstaff
    Never mind coops we can't all be northerners.
    Great saying though " have a ganders"
  16. Jez
    Jez Active Member
    I have a 2013 blade and it only came with 1 key, I got a chip and a key blank from ebay , local key cutters did the key then you have a bit of jiggery-pokery connecting a wire with a 100 ohm resistor to earth or maybe live it was a few years ago, then flashes on the dash, You can you tube programming chipped keys it is on there
    anyway it worked for me but if you can get one cloned probably far easier
  17. Jez
    Jez Active Member
    Re reading the cloned key post, these are not cloned keys, hiss is reprogramed same as I did, you only need a 10p resistor and a bit of wire, you will still have to go through the same jiggery pockery
