Damage from a falling door!
Discussion in 'Parts, Accessories & Clothing' started by Black, Feb 16, 2014.
  1. Black
    Black Active Member
    Typical and I should have known better but I was clearing out my garage today and leaned a door up against a wall. About 5 seconds later and giving me just enough time to get out of the way, the door fell on top of my blade. What an arse! :mad:
    Anyway I've been looking on flea bay to see if I can pick up an genuine Honda mirror (Right Hand Side) and there are several which say they are for the 1000rr 05 but all seem to quote different part numbers. Anyone know what the correct Honda part number is?
    Thanks.
  2. ShinySideUp
    ShinySideUp Elite Member
    Hi mate,
    Sorry about the mishap but going by this parts link
    The parts numbers should be rhs- 88110-mel-013
    Its the same part numbers for all uk 05 blades.
    Hope that helps u get what your needing. :)
  3. Black
    Black Active Member
    Excellent! Thanks for that ill plug it in and see what I can find.
    Cheers.
  4. martinowen
    Did you get away with just the damage to the mirror or was there more?
  5. Black
    Black Active Member
    Snapped mirror leg, scuff to the screen but got the standard one to put on and a snapped fairing bolt. No damage to the fairing as far as I can see but will no doubt find something else when I bring out the polish. Lol
    Not bad really and I can only be happy that it fell on mine and not the S1000rr which was sitting next to it cause it's not mine..
  6. martinowen
    Could of been alot worse then, lucky escape
  7. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    I had the wind blow the garage side door open which had a metal ramp propped up against it, that fell straight into my blade and scratched a big gouge down the tank :mad:
  8. Black
    Black Active Member
    No way man that's way worse then me. For some reason damage to the tank is way more painfull than most other panels. Was it recent or have you had the many months required to calm down? Lol
