Dashboard appears to be stuck in 1st gear.
Discussion in 'Maintenance' started by Odium-fr, Jun 6, 2018.
  1. Odium-fr
    Odium-fr Active Member
    Hi guys,
    I'm experiencing my first problem in 4 years with my 2010 blade.
    Last week, I mounted a quick action throttle. I had to go to the throttle body. It's not the first time I do it so I knew what I was doing.
    Today I did a few miles to check how it feel, and I've seen that my Healtech Gipro display "1" in every gear I am. The speed displayed on the dash is also very low... (must be calculated with revs and gear engaged I think).
    I then decided to check if I didn't forgot any connection, and no, everything is well reassembled.
    I tried with my Healtech Speedohealer disconnected, the same thing happens...
    I precise that the bike runs very well when I ride it, excpet that I don't know what is my speed and gear...
    What could be the problem??
  2. SpeedoX
    SpeedoX Active Member
    Dodgy speed sensor or its connection?
  3. Odium-fr
    Problem solved
    SpeedoX you were probably on the good way !
    I also suspected the speed sensor.
    I cleaned it and did a reset of the speedohealer.
    Now working again. Don't know what was the real problem...
  4. nigelrb
    This would be the most ironic thread on the whole forum!
    A speedo fault fixed by a member with the user name @SpeedoX . Love your work!!:cool::cool:
  5. SpeedoX
