Diagnostic Port Data
Discussion in 'General 1000RR Discussion' started by grip-wolrd, Dec 22, 2017.
  1. grip-wolrd
    grip-wolrd Active Member
    Does anyone know what format the data is being sent out of the diagnostic port?
    Would like to know if i can read it.
    Thanks,
    Ben
  2. Muffking
    Not sure what the data is like, but unlike an OBD port on cars there is a dedicated kit for Honda bikes.
  3. grip-wolrd
    I'm wondering if its possible to read the data, like the Gear Indicator kits read the speed and RPM.
  4. derchef
    derchef Well-Known Member
    It´s possible read the data on not euro4 bikes
    suggest you to have a look on cb1000r.it
  5. scooby
    scooby Elite Member
    honda are very secretive about thier protocols regarding the info via the OBD port,but Aim do a ECU lead that connects via the OBD port which reads the following,
    ECU_1 HDS_RPM RPM
    ECU_2 HDS_TPS_V Throttle position sensor voltage
    ECU_3 HDS_TPS Throttle position sensor
    ECU_4 HDS_ECT Engine coolant temperature
    ECU_5 HDS_IAT Intake air temperature
    ECU_6 HDS_MAP Manifold air pressure
    ECU_7 HDS_BATT Battery supply
    ECU_8 HDS_SPD Speed
    ECU_9 HDS_IGN_ANG Ignition angle
    ECU_10 HDS_INJ_Tms Injection time
    ECU_11 HDS_unk Unknown channel
    which isn't a lot compared to the BMW s1k for example (it reads over 30 different parameters).
    if using an Aim logger connected via the ECU lead (Aim solo DL for example),you can add a math channel which will give you gear position aswell.
  6. derchef
    On euro3 an older bikes that´s normal for lot of brand
  7. grip-wolrd
    Does the SC57 have OBD?
  8. derchef
    Even the sc 77 2018 have no standard OBD connector , 57-59-77 they got the same connector .
    Sc57 was the first to use Diagnostic data system
    On euro 4 bikes it´s possible built/buy a cable with honda 4 pins connector and ODB on other side and that read datas with a simple OBD can2 reader
    Come ti dicevo se guardi sul forum Cb1000r.it trovi un utente che sta facendosi un lettore che andra a funzionare
    Diversamente sconsiglio l acquisto delle copie cinesi dell hardware healthtech
  9. scooby
    scooby Elite Member
    tell me yr and i'll let you know.
    it's nothing to do with the OBD/diagnaostic plug type,it's the prorocols that honda use,but as the early hondas have little or no electronics aids as such ,theres not a lot of info to be taken from the data anyway.
    the Aim stuff reads from 08 onwards,may even do 04-07 but would need to check
  10. derchef
    protocols was changed with euro 4 models.
    Yes aim will work also with the sc57
  11. grip-wolrd
    I have a 2005 CBR1000RR.
    This is what I thought; but is the protocol similar to OBD?
    Grazie, ti ricordi il nome dell'utente?
    Vorrei leggere i dati dal ECU tramite un Arduino e poi trasmetterli su uno schermo o loggare.
  12. derchef
    #12 derchef, Dec 24, 2017
  13. scooby
    scooby Elite Member
    what is it your looking to do?
    read data from the ECU,or read fault codes?
    fault codes come up via the dash/MIL light,you just need to then work out what the flashes/blinks correlate to in the service manual.
    if your looking for data,or to log the data for analysis,then the aim soloDL will do it if you connect via a ECU patch lead.
    just so happens i have both for sale haha
  14. grip-wolrd
    Haha, how convenient :D
    I'm actually looking to read the data via Arduino. With this data there are a lot of things I can do such as Gear Position Indicator and Quick-Shifter and then eventually logging too.
    I know it is relatively easy to read OBD data and because the GI-Pro and such do the same i figured the Honda protocols would also be somewhat easily.
