Does replacing the clutch cable result in a smoother clutch action?
Discussion in 'Maintenance' started by SefuBanilor, Jan 17, 2016.
  1. SefuBanilor
    SefuBanilor Active Member
    Hy guys!
    I have a 08 sc59 and pulling the clutch lever requieres a forearm as Popeye has. Some other friends of mine that have sc59, don't have such a hard operating clutch. My bike has 20.000 KM.
    I lubed it, there was a small improvement but not much... I disconnected it from the lever and if I pull and push the cable, is goes smoothlly.
    I won't like to buy a new cable and end up with the same thing, so I would like to ask you guys if anyone of you replaced the clutch cable and noticed any improvement. Thank you!
  2. Lozzy
    My cable was doing the same at roughly same mileage & I noticed it was fraying. Nipped it to garage & my mate found that it was catching where it was going into the engine casing area causing the fraying. Popped me a new cable in & adjusted the cock up that had been done by previous garage & its been sweet as since & I'm on 32k now.
  3. tony lomas
    tony lomas Member
    Hi changed my cable to on my 10 plate only because changed the levers for asv and I damaged the end of the cable.pain easy to do thou
  4. RepsolPaul
    RepsolPaul Well-Known Member
    Changed mine and it also made it easier.
  5. SefuBanilor
    Well, thanks guys! I will post some updates as soon as I change mine :D
  6. SefuBanilor
    SMOOTH Operation now! I'm writing this, maybe it will be useful for somebody later on.
    Although my cable wasn't fraying or didn't have any damage what so ever I replaced it and now I'll pop wheelies like magic :p One more thing was that you have to trace the cable through a special hole on the upper side of the radiator, which twists the cable a lot. I traced the cable in a more straight line and the operation is even smoother. The only inconvenient is that the cable goes up in front of the dash now, because the cable has longer path. But just next to that place where you stick the key in to start the wheelie machine :) the cable goes through a metal wire holder. I zip tied the cable to that holder the way I wanted so the cable won't get to much in front of the dash. :D
    So if you have a hard operating clutch, i recommend you to change the clutch cable if it has some milage although it isn't fraying. VRUUUM :p
  7. ColinBR
    Other thing you can do is spray grease down the cable. This should be part of your yearly maintenance.
  8. SefuBanilor
    I did that before the season started and... no improvement :))
  9. dansp1
    dansp1 Active Member
    Not really, before cables were nylon lined lubrication was needed, modern cables with nylon lining go stiff when the nylon is worn through on tighter radius turns
  10. ColinBR
    So are you saying you shouldn't grease the cables?
    With the grease in the cables I would hazard a guess that it would help prevent the nylon being worn in the first place. But hey what do I know o_O
  11. dansp1
    Do you still boil your chain on the stove in a tin of Duckhams?
  12. ColinBR
    Mate I'm not even that old to know WTF Duckhams is.
    Anyway how's that SP1 of yours running you still got it?
  13. Dave dunlop
    Dave dunlop Elite Member
    My old man used to use this on his Honda CB250... it stank the house out and has like treacle syrup! Thank god for chain lube:D
  14. dansp1
    SP is still in bits, i have nearly finished building a trick motor for it (flowed heads hc pistons, c/r box full motec ecu race alternator sp2 throttle bodies etc)
    It has been nearly ready for most of this year, unfortunately i have been tied up most of the year with family illness
  15. Dave dunlop
  16. dansp1
    and o ring and x ring chains
  17. Dave dunlop
    That's true.... we are very spoilt these days:D
  18. bonjo
    bonjo Active Member
    Very good info pal
    don't suppose you have a pic of the tight cable routing spot?
    I wouldn't be surprised if over time, dirt and fluff gradually line the inside of the tube and restrict the cable movement at those tight spots. I normally spray PTFE or GT85 lube down the cable hoping it washed the dirt down
  19. bonjo
    bonjo Active Member
