Dynojet Power Commander 5 - PC V Fireblade 2011 ( Reduced to 190 GBP Delivered ) I am selling all my Accessories which were installed on my 2011 ABS Repsol Blade. 5. Custom Map installed for Akrapovic Slip on without DB Killer Power Commander V features. • Reduced size from PCIIIusb (less than half of the size of PCIII) • USB powered from computer (9 volt adapter is no longer needed for programming) • 2 position map switching function built in (map switch not included) • Gear input (allows for map adjustment based on gear and speed) • Analog input (allows user to install any 0-5 volt sensor and build an adjustment table based on its input such as boost or temperature) • With gear position input connected the PCV is capable of allowing each cylinder to be mapped individually and for each gear (for example: on a 4 cylinder bike with a six speed transmission there could be up to 24 separate fuel tables). • Unit has a -100/+250% fuel change range (up from -100/+100%). This allows more adjustment range for 8 injector sportbikes • 10 throttle position columns (up from 9 on PCIIIusb) • Enhanced “accel pump” utility (increased adjustment and sensitivity ranges) GBP 190 Delivered ( Reduced ) SOLD
