Dynojet QS help please
Discussion in 'Mods, Upgrades, Accessories and Products' started by StanleyRR, Jul 31, 2014.
  1. StanleyRR
    StanleyRR New Member
    Is anyone on here running a PC3 with their own QS module? Ive been reading up and apparently the blade has a a secondary injector meaning I need to buy the expansion module or the ignition module. Ideally id like some tips off someone running this set up fro an RR5. Cheers
  2. lambchops
    lambchops Elite Member
    Hi Stanley,
    I have PC3 and HM QS, no need to if your QS is one which cuts the spark and not the fuel.. If your QS works by cutting the fuel then I guess you would need to cut fuel on the secondary injectors for a really smooth change... I presume your not using the Dynojet QS as you need a PC5 for those so presume you mean with another make QS?
  3. StanleyRR
    Thanks for the info mate. You can use the Dynojet with the PC3 (USB) so yes looking down that route. I had this set up on the 954 but sadly this second injector is being a pain in the arse lol. Might be better getting a standalone unit like you said.
  4. lambchops
    Yes would probably work out cheaper... HM have just brought out a budget shifter for about £200 quid could be the best option maybe?
  5. StanleyRR
    I think your right mate, gonna cost more than that just for the module and the shifter. TBH im not even that fussed on the PC3, ive just won it so might flog it straight on. That being said id like a different exhaust on so might be worth keeping. Ill check that HM model out.
  6. sps170373
    HM quickshifters are the best and I reckon they will make a fortune with their new budget shifter
