hi all, I've had the standard exhaust off the bike and when I've put it back on I've got the engine management light on, 4 slow flashes 3 quick ones. It's a 2014 bike. I've tried the ecu reset with no luck. How do I get into the servo so I can try getting it back to the correct position? Thanks in advance.
Hoping for a bit more help!! I've got to the servo thanks to mazy, what's the correct position for the servo and the correct order for the ecu reset?
From what I can remember I think the hole for the stud on the servo wheel should be facing rear of bike. Turning ignition off & back on should reset error. You should hear servo motor initialise. If not turn servo wheel 1/4 & try again
I've tried turning it and you're right it resets itself but the error is still there. I'll give it another go tomorrow. I've got a new can coming for it next week
