ECU?
Discussion in 'Forum Announcements' started by ChrisT, Jan 30, 2021.
  1. ChrisT
    ChrisT New Member
    Thanks a lot guys, seems I have some more probing to do when time allows.
    The PGM fuse is as written on the diagram I was handed a while ago. I now see this is the F1 fuse in your diagram. The diagram I have is for a US model so does look different indeed for some reason. I'll let you know how I get on.
  2. Fatboy
    Fatboy Active Member
    I never like to blame the ECU, thats the last thing I blame as they cost so much to replace ,and seldomly is the part that fails, need to look for that power drain start from the battery and test from there ,as @Muffking says pull out fuses sensors till you can find where the short could be
  3. Muffking
    US models didn't have a HISS immobiliser, or a cat, so probably don't have O2 sensors either.
    There's not much difference in the wiring, but it's worth bearing in mind if yours has HISS or not as that may affect which diagram is better suited to your bike.
  4. ChrisT
    ChrisT New Member
    I'm at a loss as to where these are located: And yet I've probably unplugged them already not knowing what they are :D
    • IAT sensor (what ever that is).
    • Crank Position Sensor.
    • MAP sensor.
    • Throttle Position sensor.
  5. Fatboy
    Intake Air Temperature IAT ,on your Air Box
    Crank Position Sensor, inside Clutch Cover
    MAP sensor, Manifold Absolute Pressure mounted on Fuel rail
    TPS throttle Position sensor, attached to Throttle Body (can be checked with voltage)
    If you have unplugged the Crank position sensor then you wont have a spark
    You probably wont have a O2 sensor on your bike
    The only item here to stop your bike from starting is the CKP
    #25 Fatboy, Jan 31, 2021
  6. Boothman
    Boothman Elite Member
    @ChrisT hasn’t been on the forum since October 2021 so you may not get a response
