Electrickery advice needed.. Heated grips..
Discussion in 'Maintenance' started by Blackness, Jan 18, 2015.
  1. arthurbikemad
  2. ShinySideUp
    ShinySideUp Elite Member
    I would highly recommend you install a relay and use that to put power to your grips.
    The problem with just tapping into existing systems is that they have been fitted to the bike to withstand a known power draw like all the lights and headlamps on the bike going through a 20amp fuse and wiring thickness capable of handling 20amps without issues but adding another device that could draw another 5 amps can cause excess heat build up in the wiring possibly causing fires before the fuse pops up front!
    A relay only requires a very small current to turn the relay on so poses very little risk from taping into existing wiring.
  3. Blackness
    Blackness Active Member
    Thank you mate... You are a true gent... Gonna have to find somewhere to bolt the fire extinguisher for now tho...
  4. lambchops
    lambchops Elite Member
    Love the little smiley on the battery Art :)
    I was just thinking perhaps get some heated grips on mine then read all this and decided against it..
  5. Mike07
    Mike07 Active Member
  6. sinewave
  7. lambchops
  8. Blackness
  9. Blackness
    Right... My paranoia needed quashing so i cornered an auto electrician at a local garage and run what I've done passed him to see if i was in danger of blowing up, and he said what i have done is fine... Even commented on how neat it was :)
  10. sinewave
    Rough as fuck them Auto-electricians! [​IMG]
  11. Blackness
    He of little faith ;)
  12. Barstewardsquad
    The number of times I used to dig vehicle electricians out of the doo-doos by fixing their mistakes, or covering it up is quite scarey :eek:
  13. Blackness
    Oh great, cheers, thats it, kick the paranoia off again :rolleyes:
  14. Mike07
    It's a known fact that all auto-electricians are in cahoots with bike dismantlers. They get a kick back for every one that explodes.
    Mike.
    Except ones on this forum!
    Mike.
  15. Alblade
    Alblade God Like
    All I will add is that my r and g heated grips wired to brake lamp worked for 70,000 miles and still work 100% now
    I understand reason or need for a relay but not sure necessary
  16. Alblade
    Alblade God Like
    Have some cracking video of them melting ice off on December morning in Spain 2 years back
  17. arthurbikemad
    You don't need the relay, I only add it as I like the system to fully power down when the ignition is off :) Plus I also run my sat nav feed and any other aux power from same 20a relay :)
  18. el-nicko
    el-nicko Well-Known Member
    Datatool! Had 'em on the bike for two winters. They is neat, they is HOT and they turns off with the ignition. Niiiiice.
  19. sinewave
    Did the VFR12 come with Heated Grips Nicko or U gota fit a set?
  20. el-nicko
    I've got a Datatool set ready to fit mate. They're fatter than the genuine Honda ones but a quarter the price.:)
