Engine Fault after service.
Discussion in 'Maintenance' started by Ritchierich, Feb 4, 2018.
  1. Ritchierich
    Ritchierich Well-Known Member
    Strange thing happened today. After servicing the bike I run her up going through the gears then back to neutral and the EML came on along with Suspension error warning on the dash. Switched off and re-started EML still on, do you think it will go out once ridden or has anymore else had this happen to them?
    P.S. Bike is 2017 SP1.
  2. PauloHRC
    PauloHRC God Like
    Did you service the bike yourself??
  3. MPJ
    MPJ Active Member
    Did you run it through the gears on the paddock stand ? My guess is it's a traction error code, should go out when you ride it.
  4. Ritchierich
    Yes serviced it myself and yes run it up on paddock stands too but haven't had chance to ride it yet, will update you all once ridden and thank you for the replies.
