Engine light on after installing full Akra system ?
Discussion in 'Mods, Upgrades, Accessories and Products' started by casey, Dec 31, 2015.
  1. casey
    casey New Member
    Have any of the guys who fitted exhaust or more specifically an full Akra says two had this problem. I've not actually been out on a run since I fitted it 2 weeks ago but I have started it up a couple of time and every time I start it the engine light now flashes a few times then goes off, a few moments later it does it again.
    I fitted a power commander a few days ago and I connected the O2 eliminator but the light remains flashing. I'm hoping there is a quick fix, the bike will be getting a custom map in the next week or so so will see if he can sort it but I'm hoping there is something I can do in the meantime. Maybe I've done something wrong or is this a common thing when fitting a new exhaust.
    Bike in question is a 2015 blade, full Akra system.
    #1 casey, Dec 31, 2015
  2. Shane_L
    Shane_L Member
    Have you still got the exhaust servo connected? It might just need rotating back 90 degrees (I think).
    It has been covered a lot on here maybe search it.
  3. casey
    casey New Member
    Thanks Shane, I had tried the servo already but I've just been out again and turned it a little more and the light has now gone out. I was a little worried I may turn the servo too much as it doesn't stop turning but it seems to have worked now I've turned some more.
  4. sps170373
    You'd be better off getting a servo eliminator (esrm) to avoid the warning light problems and servo problems if it turns to far with no wire attached
  5. sps170373
  6. graemewalker
    graemewalker Elite Member
    Agree speedycom
  7. casey
    casey New Member
    Thanks for the advice, where is the best place to get one from,.?
  8. casey
    casey New Member
    Just ordered one through biker discount, £42 delivered so will get this installed to be on the safe side.
  9. ShinySideUp
    ShinySideUp Elite Member
  10. casey
    casey New Member
    Just read back and didn't realise when he said "speedycom" that he was referring to a shop as I've never heard of it. Just took a look on speedycom and they're a little more expensive so hoping the one I've bought is just as good.
  11. Shane_L
    Shane_L Member
    No problem mate glad it worked. Enjoy the new exhaust. :D
