Feeler gauges / valve clearances help
Discussion in 'Maintenance' started by Rr-Len, Jan 20, 2015.
  1. Rr-Len
    Rr-Len New Member
    So iv exposed the cams ready to do valve clearance check, brought some new feeler gauges.. They are metric which go up in 5's ie 0.05,0.10,0.15 so on so on..
    Haynes manual says between 0.13 - 0.19 for inlet valves..
    Am I bein stupid here as I was told mm was metric? With these feeler gauges and most iv looked up they all seem the same so I won't be able to messure accurately..
    Any help apriciated
  2. red5
    red5 Well-Known Member
    Use the 0.15 feeler for the inlet valves.
    #2 red5, Jan 20, 2015
  3. Rr-Len
    Rr-Len New Member
    So u sayin if 0.15 goes in but 0.20 don't go in then guess it's ok?
  4. red5
    Yes
  5. red5
    What model is it?
    2008-2013
    Inlet 0.16 +/- 0.03
    Exhaust 0.3 +/- 0.03
    #5 red5, Jan 20, 2015
  6. Rr-Len
    Rr-Len New Member
    2004
  7. red5
    If your just checking I'd do as discussed but if you need a re- shim your gonna need some more accurate feeler gauges.
  8. Rr-Len
    Rr-Len New Member
    Yeah just checking... So y does manual say from 0.13? Cos surely it should be anything below 0.19? If u see what I mean...
  9. red5
    Yes anywhere between the two parameters is acceptable.
