Fettling with the 2012 exhaust system
Discussion in 'Mods, Upgrades, Accessories and Products' started by samd1985, Dec 18, 2012.
  1. samd1985
    samd1985 Active Member
    Hi all,
    I've been considering the idea of removing the cat from the stock exhaust system on my 2012 blade; keeping the standard look but in the hope of some increased performance. I am, however, aiming to buy a second hand exhaust to make these changes to, rather than potentially ruining my own one.
    Where is the cat exactly? Is it integral to the stock backbox? Would it be worth doing for added noise and performance benefits, and has anyone done this before?
    Sam
  2. arthurbikemad
    Here you go mate
  3. samd1985
    That's brilliant, thanks Arthur! Getting into it looks like a challenge...
  4. megawatt
    megawatt Well-Known Member
    I have a 2010 silencer if you want to dismantle it. There's a write up somewhere on what to do.
  5. samd1985
    Drop me a pm mate, how much are you looking for for it? Is it the same silencer as the 2012? They look identical, so I can only assume so
  6. samd1985
    Excellent info guys! I think i have enough to go on now to do it myself. Just need to find a metalwork fabricator
  7. JM1
    JM1 Active Member
    No probs mate. The 08-12 silencers are all the same.
  8. megawatt
    "Just need to find a metalwork fabricator" that's what I do in my garage. I make silencers, linkpipes and collectors.
  9. samd1985
    Its a shame you're not local, else I'd be knocking on your garage door for some help welding!
  10. runningonempty
    runningonempty New Member
    Nice on Auther. This cut away of the exhaust should help me loads with the prob ive got. Apparently that weird setup valve inside can stick and cause loads a grief. Prob, how to get at it!!?? . Lol
  11. samd1985
    I did this to mine. Gutted everything - cat, valve and plate that it sits on plus various bit of pipe from inside the exhaust. Made it into one big chamber. It's great, really pleased with it and sounds good too
    Here's the cut lines:
    Here's a picture of it with the rear cut open and my mate attacking it with a plasma cutter
  12. runningonempty
    yeah, looks like the way i want to go. Cheers man.
