filter new exsaust
Discussion in 'New Members' started by john k, Apr 1, 2018.
  1. john k
    john k Active Member
    Hi I'm john put a k and n air filter and a gpr exsaust on my blade 2009 and now its being funny top it now become boggy and bottom end has dropped of too any one has advice for me about this please
  2. nigelrb
    Hi John, and welcome.
    I suspect it has affected your mapping from the ECU (Engine Control Unit). Generally it is said that an aftermarket end can does not require remapping - however that is not always gospel.
    I hope one of the more technical wizards can steer you right during the afternoon.
  3. john k
    Nice one I will await sum more replys I did think it would probs be affecting ecu I will need to get it remaped then I'm just outside of Carlisle any one around my area thats good with a remap on ecu
  4. john k
    If any one know sum company thats good let me know please thks
  5. bradt
    bradt Elite Member
    Welcome John
  6. john k
    Thanks bradt
  7. BlackDevil
    BlackDevil God Like
    Hi and welcome John !
    You need a power commander and a custom remap etc.
  8. john k
    Nice one blackdevil cheers for that wondering can I get the ecu thats on remap or am I best to get power commander too
  9. BlackDevil
    BlackDevil God Like
    It depends. A reflashed ECU is one option and probably the best solution in my opinion. You will have several options if you go for the PC5. There is an auto tune option as well and you can remove the parts if you sell the bike.
    Also, it depends how good the tuner is and the Dyno. You have to find a very good Tuner in your area.
    The following company did the work on my Blade and I was very satisfied with them:
    http://pdq1.com/
  10. john k
    Spot on good doo I will check them out thanks a reflashed ecu will be the cheaper option I guess I will be happy with that 1 map I fine once its set up to the bike be good and right
